on 01-05-2023 20:34
I am making this post to help me converse with support agents. I had similar issues in the past, some 8 months ago, and they were resolved. Unfortunately, they are back.
My hub loses connection to the Virgin network every 2-3 hours, and sometimes - up to 2-10 times in a quick succession (say, every two to five minutes).
Does anyone else experience something similar? I am really curious to know why issues have returned.
Hub status:
Cable Modem Status
Item Status Comments
203000000
Locked
Ranged Upstream Channel (Hz)
49600000
Locked
Provisioning State
Online
1 203000000 -0.2 38 256 qam 9
2 139000000 2.7 37 256 qam 1
3 147000000 2.2 38 256 qam 2
4 155000000 2 37 256 qam 3
5 163000000 1.4 38 256 qam 4
6 171000000 1.2 37 256 qam 5
7 179000000 0.7 38 256 qam 6
8 187000000 0.5 38 256 qam 7
9 195000000 0 38 256 qam 8
10 211000000 -0.7 37 256 qam 10
11 219000000 -0.9 38 256 qam 11
12 227000000 -1.2 37 256 qam 12
13 235000000 -1.7 37 256 qam 13
14 243000000 -2 37 256 qam 14
15 251000000 -1.7 38 256 qam 15
16 259000000 -1.5 38 256 qam 16
17 267000000 -1.2 38 256 qam 17
18 275000000 -1.5 38 256 qam 18
19 283000000 -1.4 38 256 qam 19
20 291000000 -1.5 37 256 qam 20
21 299000000 -1 38 256 qam 21
22 307000000 -1 38 256 qam 22
23 315000000 -1.2 38 256 qam 23
24 323000000 -1.2 38 256 qam 24
1 Locked 38.6 31657670 4652131
2 Locked 37.6 102203993 44716964
3 Locked 38.6 116199065 36899466
4 Locked 37.6 64524514 15104838
5 Locked 38.6 46339229 8470528
6 Locked 37.6 44152130 7725472
7 Locked 38.9 41734979 6930680
8 Locked 38.9 37851007 6039874
9 Locked 38.6 34017853 5199469
10 Locked 37.6 31480753 4588730
11 Locked 38.6 27428723 3920635
12 Locked 37.6 25112740 3421372
13 Locked 37.6 23567164 3137979
14 Locked 37.6 22575929 3021643
15 Locked 38.6 20117299 2661086
16 Locked 38.6 15973487 2027973
17 Locked 38.6 13340218 1694709
18 Locked 38.6 11880278 1499578
19 Locked 38.6 10572988 1334436
20 Locked 37.6 10001126 1239730
21 Locked 38.6 9329981 1154862
22 Locked 38.6 7545599 965856
23 Locked 38.6 6277910 819657
24 Locked 38.6 5431858 725553
1 49600000 41 5120 64 qam 1
2 23600000 41.2 5120 16 qam 5
3 30100000 41.3 5120 64 qam 4
4 36600000 41 5120 64 qam 3
5 43100000 41 5120 64 qam 2
1 ATDMA 0 0 5 0
2 ATDMA 0 0 849 0
3 ATDMA 0 0 381 0
4 ATDMA 0 0 71 0
5 ATDMA 0 0 11 0
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt053+voc-b.cm
SFID 4110
Max Traffic Rate 575000000
Max Traffic Burst 42600
Min Traffic Rate 0
Primary Upstream Service Flow
SFID 4109
Max Traffic Rate 38520000
Min Traffic Rate 0
Max Concatenated Burst 16320
Scheduling Type BestEffort
01/05/2023 19:10:14 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 18:52:43 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 17:42:0 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 15:20:22 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 15:19:40 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 15:10:41 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 15:09:2 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 15:08:41 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 12:51:5 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 12:50:53 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 12:50:53 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 12:50:52 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 12:50:51 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 12:50:50 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 12:50:49 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 12:50:41 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 12:48:43 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 12:39:25 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 12:39:24 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/05/2023 12:39:14 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
on 04-05-2023 09:16
Hi there @adept 👋 Welcome back to our forum and thanks for your post 😊
Sorry to see you've been having issues with your connection dropping, I can certainly understand the frustration with this 😔 I have taken a look at our system for you and can see that there does seem to be some issues with the service.
I'll send you a PM to confirm your details so this can be discussed further.
Nathan
on 05-05-2023 12:53
Thanks for chatting with me via PM @adept 😊 I'm glad to have been able to arrange for someone to come and take a look at your connection.
Please be aware that someone over the age of 18 must be present during the visit, also if the engineer appointment is missed there may be a £25 charge added to the account.
You can view the appointment via your online account here.
Keep us posted with how this goes, if you need anything further, we'll be happy to help.
Nathan
on 11-06-2023 11:45
I've had an engineer visit around the Coronation Day, he did some tests inside the house, and then worked in the street cabinet, and everything was just fine for a while. So in this regard, I see a pattern - it looks like it is not a problem with my hub/home wiring, but rather something outside (in the street cabinet and beyond).
Unfortunately, my problem-free state did not last, I am now back to this, where sync is lost 5-6 times an hour during the day:
11/06/2023 11:34:38 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 11:32:1 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 11:27:54 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 10:58:56 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 10:51:14 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 10:01:46 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 10:01:45 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 09:21:15 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 09:11:54 critical No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 09:11:24 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 09:11:20 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 02:54:8 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 02:51:1 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 02:29:23 critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
11/06/2023 02:28:3 Warning! RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
I don't think this could be rectified without another visit, does it? Would you be able to help me arrange it please?
on 13-06-2023 11:57
Hi @adept
Thanks for coming back to the thread. I am sorry to hear you're still having broadband issues. I can see from the system check that we have booked you another visit. Please let us know how it goes.
Best wishes.
15-06-2023 16:34 - edited 15-06-2023 16:35
sorry posted in wrong thread.
on 19-06-2023 21:14
Got and engineer visit who plugged me into different port in the street cabinet and upgraded me from Hub3 to Hub5. So far so good! (knock on wood)
