on 26-11-2023 18:42
Can someone give advice,my WiFi pods won't connect to my new hub 5.when connect with ethernet it works but not WiFi.worked with old router
26-11-2023 19:00 - edited 26-11-2023 19:03
Sounds like they haven't been registered with the new HUB.
It should be automatic, however, doesn't happen every time.
You need to contact VM to correct.
on 29-11-2023 10:36
Hi there @Andyholmed
I am so sorry to hear that your new Hub has not yet connected to the Pod's and a big thank you to carl_pearce for their advise so far.
I would be more than happy to take a closer look into this with you via a private message. I will pop you a PM across now, please keep an eye out for the envelope at the top of your screen alerting you to a new message.
