Volt package. Hub3 on continuous red
chapmantimsan
Hub 3 box stuck on red. Done switching on and off and reset. Checked all connections. Box is not hot and wi-fi appears to be working. Awaiting a moderator please.
1 REPLY 1
If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
