Port forwarding?
DanyYo
I have an unit connected, having a web server and other TCP utilities. Set up with static IP 192.168.0.8. When addressing from inside the network, all is fine.
I am setting forwarding of both 80 and 9500 (80-80, 9500-9500), but when approaching from outside, the unit does not respond, like the ports are not forwarded?
4 REPLIES 4
Use hub in modem mode and test that works then get a router with 1Gb ports that works.
Legend
Are you configuring the port forwards on a VM Hub in Router mode or on a 3rd Party Router ?
Do the ports 80 and 9500 appear to be open or closed when probed from the public internet ?
In router mode, it is a router, isn't it?
Closed when probed.
jpeg1
If you want to do anything other that basic default settings, it's best to use your own router.
Port forwarding is a simple operation that should work on a VM Hub, but for the small cost of a new router you will have total control of everything you need to do.
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
