a month ago - last edited a month ago
I am rearranging some wiring and I have noticed latency double since switching hub 5 to router mode:
Immediately before switching to router mode (using edgerouter ER Pro 8):
Any ideas?
a month ago
Difficult to know without more extensive tests but there's something very odd going on there.
Have you run BQM for a while in each mode with just one device connected by ethernet. Leaving your own router out of the equation.
a month ago
a month ago
You need to run for a few hours with everything removed except one ethernet device. Overnight if that's easiest. Are you running two BQMs, one for each WAN IP?
4 weeks ago
4 weeks ago
It looks like rate limiting QoS/BWM
I suggest modem mode with a PC allow ICMP with BQM under a new IP
4 weeks ago
It suggests to me that there are problems outside your own internal network.
4 weeks ago
or you can setup a new BQM for VM WAN gateway and see if thats flat
3 weeks ago
3 weeks ago
Glad to hear some of the advice has helped roodles.
How did you get on with this, is everything now okay?
Matt - Forum Team
New around here?
