on 15-11-2023 20:08
Hi all,
How do I report an issue I have with a game (World of Tanks) where I have started having bad lag which is affecting gameplay?
I have run a ping trace and identified where there is extreme packet loss and the same ping using a VPN is clean with no packet loss on any of the hops at all. I have the traces saved, I just need someone at VM to investigate it because I do not want to have to spend more money to use a VPN on top of my VM subscription.
Mark
on 15-11-2023 20:18
Here are 2 screenshots, the first via VM the second via Surfshark UK VPN.
Note the 80% PL at 84.116.137.57 via VM
on 18-11-2023 10:50
Hi @mo0g 👋
Welcome back to our Community Forums and thanks for your post.
I am sorry to hear you're experiencing issues whilst gaming.
Is this just happening on this one particular game?
Are you using a wired connection?
on 18-11-2023 12:06
It is apparent in only one game although it could well be happening in other games, I guess it depends on whether all network traffic from my hub goes through that aorta.net hub or not.
Yes I am using a wired connection, 1gb ethernet to switch then 1gb to router then 1gb to vm hub, although if it were due to a wireless issue I'd be getting the same problem via the VPN? This is a problem with the network outside my house and nothing to do with my set up. I have been through the support process with the game support team and they concur.
We need to know why there is such ridiculous packet loss at 84.116.137.57 and/or do something to route me via somewhere else.
on 20-11-2023 13:10
Thank you @mo0g we are so sorry to hear that these issues have continued and thank you for popping back.
Can you post your Hub status and logs? How to do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum
on 20-11-2023 14:39
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 5 |
DOCSIS 3.1 channels | 1 | 1 |
on 20-11-2023 14:40
1 | 139000000 | 6.800003 | 40.366287 | QAM256 | 1 |
2 | 147000000 | 7.099998 | 40.366287 | QAM256 | 2 |
3 | 155000000 | 7.199997 | 40.366287 | QAM256 | 3 |
4 | 163000000 | 7.000000 | 40.366287 | QAM256 | 4 |
5 | 171000000 | 7.300003 | 40.366287 | QAM256 | 5 |
6 | 179000000 | 7.599998 | 40.946209 | QAM256 | 6 |
7 | 187000000 | 7.699997 | 40.946209 | QAM256 | 7 |
8 | 195000000 | 8.000000 | 40.366287 | QAM256 | 8 |
9 | 203000000 | 8.099998 | 40.366287 | QAM256 | 9 |
10 | 211000000 | 8.199997 | 40.366287 | QAM256 | 10 |
11 | 219000000 | 8.300003 | 40.366287 | QAM256 | 11 |
12 | 227000000 | 8.500000 | 40.946209 | QAM256 | 12 |
13 | 235000000 | 8.699997 | 40.366287 | QAM256 | 13 |
14 | 243000000 | 9.000000 | 40.366287 | QAM256 | 14 |
15 | 251000000 | 8.800003 | 40.366287 | QAM256 | 15 |
16 | 259000000 | 9.000000 | 40.946209 | QAM256 | 16 |
17 | 267000000 | 9.000000 | 40.946209 | QAM256 | 17 |
18 | 275000000 | 8.699997 | 40.366287 | QAM256 | 18 |
19 | 283000000 | 8.199997 | 40.946209 | QAM256 | 19 |
20 | 291000000 | 8.199997 | 40.366287 | QAM256 | 20 |
21 | 299000000 | 8.599998 | 40.946209 | QAM256 | 21 |
22 | 307000000 | 9.099998 | 40.366287 | QAM256 | 22 |
23 | 315000000 | 9.300003 | 40.366287 | QAM256 | 23 |
24 | 323000000 | 9.099998 | 40.366287 | QAM256 | 24 |
25 | 331000000 | 8.699997 | 40.946209 | QAM256 | 25 |
26 | 339000000 | 8.500000 | 40.366287 | QAM256 | 26 |
27 | 347000000 | 8.099998 | 40.366287 | QAM256 | 27 |
28 | 355000000 | 8.199997 | 40.366287 | QAM256 | 28 |
29 | 363000000 | 8.099998 | 40.946209 | QAM256 | 29 |
30 | 371000000 | 8.099998 | 40.946209 | QAM256 | 30 |
31 | 379000000 | 8.300003 | 40.366287 | QAM256 | 31 |
1 | Locked | 40.366287 | 0 | 0 |
2 | Locked | 40.366287 | 0 | 0 |
3 | Locked | 40.366287 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
5 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.946209 | 0 | 0 |
7 | Locked | 40.946209 | 0 | 0 |
8 | Locked | 40.366287 | 0 | 0 |
9 | Locked | 40.366287 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 40.366287 | 0 | 0 |
12 | Locked | 40.946209 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 40.366287 | 0 | 0 |
15 | Locked | 40.366287 | 0 | 0 |
16 | Locked | 40.946209 | 0 | 0 |
17 | Locked | 40.946209 | 0 | 0 |
18 | Locked | 40.366287 | 0 | 0 |
19 | Locked | 40.946209 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.946209 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
25 | Locked | 40.946209 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.366287 | 0 | 0 |
28 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 40.946209 | 0 | 0 |
30 | Locked | 40.946209 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
33 | 96 | 4K | 1840 | QAM4096 | 759 |
33 | Locked | 43 | 5.0 | 1314284210 | 1720 |
on 20-11-2023 14:40
1 | 36600000 | 42.520599 | 5120 KSym/sec | 64QAM | 3 |
2 | 23600000 | 42.020599 | 5120 KSym/sec | 16QAM | 5 |
3 | 30100000 | 42.270599 | 5120 KSym/sec | 64QAM | 4 |
4 | 43100000 | 42.770599 | 5120 KSym/sec | 64QAM | 2 |
5 | 49600000 | 43.270599 | 5120 KSym/sec | 64QAM | 1 |
1 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
6 | 10.8 | 47.0 | 2K | QAM128 |
6 | OFDMA | 220 | 53.4 | 0 | 0 |
on 20-11-2023 14:40
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | cmreg-vmdg640-bbt076-b.cm |
SFID | 41172 |
Max Traffic Rate | 1230000450 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 41171 |
Max Traffic Rate | 110000274 |
Max Concatenated Burst | 42600 |
Scheduling Type | bestEffort |
on 20-11-2023 14:41
Mon Nov 20 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Nov 19 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Nov 19 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Nov 18 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Nov 18 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Nov 18 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Nov 18 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Nov 18 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Nov 17 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Nov 17 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Nov 16 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Nov 16 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Nov 16 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Nov 16 | 3 | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Nov 16 | 5 | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Nov 16 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Nov 15 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Nov 14 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Nov 14 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Nov 14 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Nov 13 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Nov 13 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Nov 13 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Nov 13 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Nov 12 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Nov 12 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat Nov 11 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Nov 10 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Nov 10 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Nov | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Nov | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed Nov | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Nov | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Nov | 6 | CMSTATUS:US_Diplexer_Mode_Change: (TLV-9) , (5-85) ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Nov | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue Nov | 6 | SW download Successful - Via NMS |
Tue Nov | 6 | SW Download INIT - Via NMS |
Mon Nov | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Nov | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Nov | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun Nov | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
