on 19-09-2023 07:43
My hub 3 is a few years old and appears to intermittently drop connection speed even with 3 pods. Also the light on the front has gone from a light amber to a deep amber/red. Hub speed into the hub is excellent 273 but device speed sat in front on the hub (with no other devices connected) can range from 14.2 to 242.
Would a new hub even this out as when it drops so low the pods stop and no one can use the internet in the house.
I have rebooted the hub many times and reset the connect app.
Answered! Go to Answer
on 29-09-2023 13:38
Hey @blueskies76,
Glad we were able to have that private chat to go about looking into your issue, do let me know how the appointment goes and if I can do anything further, let me know here.
Joe
on 19-09-2023 08:00
"14.2 to 242". - this may be more about the connecting Wi-Fi device that the Hub.
The lower speed suggests a device connecting on the 2.4Ghz band, the upper via the 5Ghz band.
on 21-09-2023 11:54
Hi blueskies76,
Thanks for taking the time to pop in our Community.
We're very sorry to hear you're having some issues with your connection and that your Hub 3 displaying a red light. Just to double check, is the Hub currently in modem mode? If so then the light will be a magenta colour but can look quite red at times. This is perfectly normal and nothing to worry about.
If it's not then please follow the below steps:
If the red light still shows after doing the above, pop back here and let us know. We can then arrange an engineer to visit to swap out the Hub. Once the red light issue is resolved, we can then take a look at the connection issues.
on 27-09-2023 07:43
Thanks. I’ve done this and still the same. It’s also not recognise my pods now either
on 29-09-2023 12:06
Hey @blueskies76,
Thanks for getting back to us with this, I would like to go about looking into this further with you, for me to do so I will need to confirm some information from you in a quick private message.
Joe
on 29-09-2023 13:38
Hey @blueskies76,
Joe
