Are my upstream and downstream power levels too high?
Lazy_Jamie
For over a year now give or take, I've been having intermittent drops; this is noticeable during gaming sessions. They last around 10 seconds give or take, however I still seem to be able to hear other people during the drop, and their own sharescreens through Discord WHILE the "internet" has cut out, which leads me to believe this may be an upstream problem if my extremely limited broadband knowledge is correct.
This has been happening for a year now, with no fixes in sight. The cables are tight, even restarting the router does not have any effect. It's just been a constant pain for a year now, so would appreciate any help as I am completely clueless about broadband.
3.0 Downstream channels
25331000000-4.637.6QAM25625
10211000000-4.437.4QAM25610
11219000000-533QAM25611
12227000000-5.332.3QAM25612
13235000000-4.937.4QAM25613
14243000000-4.937.4QAM25614
15251000000-5.137.4QAM25615
16259000000-637.4QAM25616
17267000000-6.237.4QAM25617
18275000000-5.137.6QAM25618
19283000000-4.337.4QAM25619
20291000000-3.737.6QAM25620
21299000000-4.237.4QAM25621
22307000000-537.6QAM25622
23315000000-5.337.6QAM25623
24323000000-5.137.6QAM25624
26339000000-4.837.6QAM25626
27347000000-4.937.6QAM25627
28355000000-4.737.6QAM25628
29363000000-3.938.6QAM25629
30371000000-3.737.6QAM25630
31379000000-4.137.4QAM25631
32387000000-537.6QAM25632
33395000000-4.237.4QAM25633
34403000000-3.538.6QAM25634
35411000000-3.538.6QAM25635
36419000000-3.837.6QAM25636
37427000000-4.437.6QAM25637
38435000000-4.138.6QAM25638
39443000000-3.938.6QAM25639
40451000000-4.437.6QAM25640
25Locked37.63627600
10Locked37.35598800
11Locked32.96266200
12Locked32.32148700
13Locked37.35598800
14Locked37.35598800
15Locked37.35598800
16Locked37.35598800
17Locked37.35598800
18Locked37.63627600
19Locked37.35598800
20Locked37.63627600
21Locked37.35598800
22Locked37.63627600
23Locked37.63627600
24Locked37.63627600
26Locked37.63627600
27Locked37.63627600
28Locked37.63627600
29Locked38.60537700
30Locked37.63627600
31Locked37.35598800
32Locked37.63627600
33Locked37.35598800
34Locked38.60537700
35Locked38.60537700
36Locked37.63627600
37Locked37.63627600
38Locked38.60537700
39Locked38.60537700
40Locked37.63627600
3.1 Downstream channels
159964K1840QAM4096759
159Locked38-11.510741240912554
If everything looks fine here, then I'm not quite sure what the next step to fix this would be.
Many thanks,
Jamie Bradley
3 REPLIES 3
They are not ideal -6 dBmV is the bottom of the recommended range and yours are all close to that with channel 17 below that value.  Also the 3.1 channel is too low at -11.
A VM person needs to take a look - one should respond shortly.
Legend
There should also be at least four DOCSIS 3.0 Upstream Channels operating in QAM 64, how do those channels look ?
Travis_M
Hi @Lazy_Jamie
Thanks for posting on our community forum and sorry to hear about the issue with your broadband.
I'll drop you a private message to collect some more information and investigate further so we can look at having this resolved for you, keep an eye on your inbox for a message from myself.
Travis_M
