2 engineer visits and still issues
cfreeman
I have had 2 engineers come and check why my internet keeps dropping, packet loss and lots of errors. The first time he added a 6db attenuator, second engineer changed the box on the wall and the metal box inside (still had telewest) and changed the attenuator to a 3db one.
I am still having issues getting lots of pre/post rs errors and lots of T2/T3/T4 errors.
3.0 Downstream channels
13310000007.941QAM 25625
2139000000941QAM 2561
31470000008.941QAM 2562
41550000008.941QAM 2563
52270000008.441QAM 25612
6235000000841QAM 25613
72430000007.941QAM 25614
82510000007.641QAM 25615
92590000007.640QAM 25616
102670000007.541QAM 25617
112750000007.741QAM 25618
122830000007.740QAM 25619
132910000007.740QAM 25620
142990000007.640QAM 25621
153070000007.740QAM 25622
163150000007.840QAM 25623
173230000007.841QAM 25624
18339000000840QAM 25626
193470000008.140QAM 25627
203550000008.141QAM 25628
213630000008.341QAM 25629
223710000008.341QAM 25630
233790000008.341QAM 25631
243870000008.341QAM 25632
25395000000841QAM 25633
264030000007.941QAM 25634
274110000007.741QAM 25635
284190000007.441QAM 25636
294270000007.141QAM 25637
304350000007.241QAM 25638
314430000007.141QAM 25639
32451000000740QAM 25640
1Locked4120550
2Locked419032
3Locked418537
4Locked419994
5Locked4112987
6Locked4114044
7Locked4115434
8Locked4120696
9Locked4022544
10Locked4120253
11Locked4118094
12Locked4024888
13Locked4026533
14Locked4027089
15Locked4027334
16Locked4023446
17Locked4122813
18Locked402450
19Locked4023581
20Locked4122713
21Locked4122383
22Locked411700
23Locked4119978
24Locked41193139
25Locked411790
26Locked411840
27Locked411650
28Locked411870
29Locked411910
30Locked411670
31Locked411820
32Locked401370
3.1 Downstream channels
159944K1840QAM 40961108
159Locked385.8958688171374
3.0 Upstream channels
04960000046.35120QAM 641
14310000045.85120QAM 642
23660000045.85120QAM 643
33010000045.35120QAM 644
42360000044.35120QAM 645
0ATDMA0140
1ATDMA0100
2ATDMA0100
3ATDMA0100
4ATDMA01342
3.1 Upstream channels
61040.22KQAM 256
6OFDMA2007400000000
6 REPLIES 6
cfreeman
28-02-2024 20:45:44noticeGUI Login Status - Login Success from LAN interface
28-02-2024 13:32:59warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-02-2024 13:32:59noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-02-2024 13:22:53warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-02-2024 13:22:53noticeUS profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
28-02-2024 09:32:16noticeGUI Login Status - Login Success from LAN interface
27-02-2024 11:09:29errorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-02-2024 09:54:45criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-02-2024 09:51:29criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-02-2024 05:03:34noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-02-2024 05:00:57noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-02-2024 02:45:05noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
27-02-2024 02:42:50noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 12:11:19noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 12:09:36noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 10:48:09noticeGUI Login Status - Login Success from LAN interface
26-02-2024 10:47:57noticeGUI Login Status - Login Success from LAN interface
26-02-2024 10:45:27noticeGUI Login Status - Login Success from LAN interface
26-02-2024 10:41:34noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 10:41:04noticeCM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 10:41:04noticeCM-STATUS message sent. Event Type Code: 5; Chan ID: 1 2 3 12 13 14 15 16 17 18 19 20 21 22 23 24 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-Q
26-02-2024 10:41:04noticeCM-STATUS message sent. Event Type Code: 4; Chan ID: 1 2 3 13 14 15 16 17 18 19 20 21 22 23 24 26 27 30 31 35 38 39 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 10:41:04noticeCM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 10:41:03warningRNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 10:41:03warningDynamic Range Window violation
26-02-2024 10:41:02warningDynamic Range Window violation
26-02-2024 10:41:02warningRNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 10:41:02warningRCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 10:41:02warningDBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 10:40:52warningMDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 10:40:52criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 10:40:48criticalSYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 06:52:23criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 06:52:23critical16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 06:48:24criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 03:54:40noticeCM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
26-02-2024 03:52:46noticeCM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
25-02-2024 21:44:28noticeGUI Login Status - Login Success from LAN interface
Steven_L
Hey cfreeman,
Welcome back to the community and thanks for taking the time to post. I’m sorry to hear of the issues with your connection are still ongoing at the moment.
I have looked further into this and cannot see anything that would be causing the issues that you were reporting on Wednesday, how are things looking right now, have you had any improvements with your connection or are you still having issues?
Kind Regards,
Steven_L
Still having really bad issues, the rs errors have gone up, over 100 t3 timeouts, and the rest
From checking we can see there are some power level issues for your downstream, this may be causing the issues experienced. But it appears the Hub was rebooted since posting and no errors are currently showing, is the case? Have the errors stopped since your post?
If not, let us know and we can arrange for a visit.
Rob
I do hope VM check more then downstream power levels when T3 are normally to do with upstream problems
Rest assured, all the relevant tests are carried out back end. Thanks @legacy1
Ayisha_B
