Diane4060's avatar
Diane4060
6 months ago
Red Light on hub 3
Hi I've had a solid Red light on my hub 3 for just over 24 hours. I checked the cables and run a diagnostic check and the temperature is normal. I've also done a pinhole reset, can anyone help please?
    If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
    • John_GS's avatar
      John_GS
      Thanks for joining us on PM Diane4060 and providing the information so we can book in an engineer visit to replace the Router.
      Please let us know how it goes.
  • Hi Diane4060
    Thanks for posting and welcome back to the community. I'll send you a PM now to assist further.
