davidbalerno's avatar
davidbalerno
Dialled in
8 months ago
Hub 3 red light on
The red light on my hub stays red all the time despite switching off and on numerous times in the last month. I still have working wifi, phone and Virgin TV. I have factory reset the hub, checked cables etc and hub temperature but still red. When I run diagnostics for the hub it says all OK. I am in router mode. When I do a status check on MyVirginMedia website it usually says unable to connect to your hub. Is there anythingelse I can check?
  • John_GS's avatar
    John_GS
    8 months ago
    Hi davidbalerno
    I'll send you a PM now to book in an engineer visit to replace the Router.
    Best wishes.
    In the Hub 3 menu >> Network diagnostic tool
    Scroll down and through the results and check if Temperature is Normal
    • davidbalerno's avatar
      davidbalerno
      Dialled in
      Thanks @Client62 - I tried this on my Hub 3 diagnostics tool but it does not tell me what the temperature is, the result just says to check among other things if the temperature is normal. The hub does not feel warm at all.
        Forget the junk Connect app.
        Did you login to the Hub 3 menu at 192.168.0.1 and run the Network diagnostic tool shown on the first page of the Hub 3 web menu ?
        I'm not convinced you have as Temperature is one of the many results.
    If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. If you wait here a couple of days a VM Mod should pick this up and discuss directly with you.
    Scroll down the list to the rest of the diagnostic results they look like this ....
    If you still think something is wrong, please check the following
    1    Gateway IPv4 address is valid.
    2    Your broadband connection is working.
    3    Your broadband connection is ready.
    4    The temperature of your Hub 3.0 is normal.
    5    The status of telephone line 1 is not ready.
    6    The status of telephone line 2 is not ready.
      davidbalerno
      Dialled in
      Yes, I have done that twice now. Sorry to contradict you but it says "please check" that the temperature is normal and please check 5 other things on that list. It doesn't say or know if the temperature is normal. It will never say "the temperature is a bit warm" or anything else. I have checked the hub and it is fairly cold so safe to say it is normal.
        Reading the list, 1 2 3 & 4 are all OK i.e. Ready / Working / Ready / Normal
        5 & 6 are not operational i.e. Not Ready in both cases.
  • I've had a right light on my hub for two days now I've done everything that people have recommended but it's still showing the red light. The hub feels warm but not hot. Any other ideas please
    • Sabrina_B's avatar
      Sabrina_B
      Hi Cheall1 👋.
      Thanks for reaching out to us, sorry to hear of the issues that you are having with a red light on your Hub. So that we can get this resolved for you we will need to bring you in for a private message, please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
      Thanks.
      Sabrina
  • Hi,
    I am also having the constant red light issue, for about 3 weeks now. The router is not hot and is exactly where the original engineer put it. I have tried switching off and on and resetting. Still a red light, please help
    • John_GS's avatar
      John_GS
      Hello Ellygrim60
      Thanks for posting. Welcome to the community and thanks for letting us know about the red light on the Hub and what you've tried. I'll send you a PM now to book an engineer visit in.
      Best wishes.
  • My hub 3 has a red light on continuously. Please send replacement.
    • Akua_A's avatar
      Akua_A
      Hi kodie1,
      Welcome to our forums, and sorry to hear you have been having an ongoing red hub light. We can understand your concern, and we want to best help. To best look into this, we are sending you a private message. Please keep an eye out for an envelope at the top right corner of your Forum page. Let me know if you have any issues locating this.
  • The same is happening on my Hub3, no reset is doing anything and no issues are being picked up. How do I contact an engineer as I cannot connect anywhere
    • John_GS's avatar
      John_GS
      Hi LauraJackson85
      We can see you've spoke to the team since your post and are getting a new Hub :).
      You'll be sent pre-paid packaging to send the old one back to us. Please do this via either Collect Plus or O2;
      https://www.collectplus.co.uk/find-a-store - click this, pop your postcode in and choose Yodel. Your local stores will then show.
      https://stores.o2.co.uk/ - click this and pop your postcode in. Your local O2 stores will also show :).
      Best wishes.
  • Hi, my hub 3 now has a permanent red light I have turned it on and off and done reset but it's still on, it was amber for the last few days now has gone red.  Please help
    • Steven_L's avatar
      Steven_L
      Hello nigethegooner,
      Welcome to the Community, and thanks for taking the time to post here on the forums. I’m sorry to hear of the issues that you’re experiencing with your router at the moment.
      I'd be happy to take a further look into this for you; however, I would need to confirm a few details via private message. Please look out for my message, and we can get started.
      Kind Regards,
      Steven_L
  • I also have this issue. I have unplugged and restarted the router and done a factory reset on the hub3 but the red light still remains. It is causing very patchy connections to certain devices. I ran diagnostics on the hub settings which said there were issues but wouldn’t tell me what they were.
    Is there anything I can do to resolve this?
    • Akua_A's avatar
      Akua_A
      Hi mwhatleyarch
      Welcome to our forums and thank you for your first post. Sorry to hear you are experiencing an ongoing red hub light. We can understand your concern and we want to do our best to help. To best look into this, we are sending you a private message. Please keep an eye out for an envelope at the top right corner of your Forum page. Let me know if you have any issues locating this.
  • jck's avatar
    jck
    Hello Virgin.
    I am struggling with the same problem, i.e. a red light on hub3.
    I don't remember when it appeared, but when I noticed it, I didn't pay much
    attention to it because I didn't have any connection problems.
    But when I noticed the colour again, I searched the internet and found out that
    it is usually related to the router overheating. So I tried all the possible
    solutions to this problem that are also on this forum. I disconnected the power
    cable overnight and performed a pinhole reset without success.
    Finally, I used the hub's 3 network diagnostic tool.
    The results showed that everything was fine. Here is the content of the report:
    Your home network has a few problems.
     Checking Broadband Service     v
     Checking Telephone Service     x
     Checking Ethernet Connections     v
     Checking WiFi Connections     v
    I also checked whether there were any problems with the internet connection in
    my area, and it turned out that there was an issue, but the repair is almost complete
    and broadband should be working.  But even if there was a problem in my area,
    I didn't notice any connection issues.
    So the only problem, or perhaps not, is the colour of  indicator on hub3.
    So how can you help me?
    • Martin_N's avatar
      Martin_N
      Hi jck,
      Thank you for your post and welcome to the community.
      We're sorry to hear about the light on your hub being red.
      We can certainly look into this. Please responding to the private message that will be sent shortly.
      ^Martin
