Chirag27's avatar
Chirag27
Red light on Virgin Media Hub
hi, I have a solid red light on my virgin media hub 3 for over 3 months. I’ve also been having issues with my WiFi dropping on a regular basis. I have called virgin media a few times and every time the advice is different by the technical people. I have done a reset of the wifi router recently and have taken out the wires and plugged them in again. Unfortunate the red light is still coming up.
  • The red LED on a Hub 3 is the overheating warning.  If this is faulty, i.e. on when it should be off, then the Hub needs replaced as it's a risk.  If you wait here a day or two a VM Mod will pick this up and discuss with you directly.
