Dane2's avatar
Dane2
Red light on Virgin Media hub 3
I have a red light on my Virgin Media Hub 3. The hub is not overheating and is in a well ventilated area. The problem is now two days old after an intermittent fault. The broadband appears to be working normally both WiFi and ethernet connection. Why am I not seeing the normal white light on the front of the hub? Should I be worried? We have tried resetting the hub several times to no avail and this has not helped.
  • Thank you for joining me over private message Dane2
    Glad we've been able to get this arranged for you today to be investigated further.
    Please let us know if you are having any further issues or have any questions at all. We'll be here to help on the Community Forums if needed.
  • Tudor's avatar
    It’s normally a fault with the hub. Please do a pin hole reset and if the red LED persists then the hub will need replacing
  • Hi Dane2
    Apologies for any issues with the Internet and the red light.
    Have you managed to do the PIN reset on the Router? If so and it's still the same red light, let us know. We can send an engineer round to replace it :).
    Best wishes.
    • Dane2's avatar
      Dane2
      Hi John, I have done the PIN reset and I still have the RED light, so I presume the router is faulty.
    • Dane2's avatar
      Dane2
      Hi John_GS, I hope i've replied in the correct place, I did the PIN reset and still have the red light, perhaps you can arrange an engineer?
      • Carley_S's avatar
        Carley_S
        Thank you for trying this Dane2
        Let's investigate further on our side. Please join me in a private message so I can locate your account and pass the account security. You can see your private messages at the top of the page, in the envelope icon, or if you're using a smaller device, you can see your private messages by clicking on the Virgin Media logo at the top right and selecting 'Messages' from the drop-down.
  • Ianmel's avatar
    Ianmel
    Up to speed
    I have had the very same problem as you for the last 3 days. Will be interested to see what the outcome is. Sounds like it's a VM problem.
  • I'm available now to try and resolve this red light router problem?
    If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. It is a potential risk and as such should be managed as such.
  • Carley_S's avatar
    Carley_S
  • My router red light problem is now resolved.  The Forum arranged for an engineer to examine and test our router and he determined that the router was on the way out. We got a new like for like router and I now have a fully functional internet again.
