on 26-10-2023 12:45
Having problems with our main box, we can turn tv in with white tv button but nothing happening with red virgin button, been through all diagnostics can’t find the fault, the tv will work through the free view box but can’t get onto virgin, we have multi room and 2nd box in other room working
on 26-10-2023 15:49
I assume the red button is turning the 360 box off to prove that the remote is working.
Your TV's HDMI-CEC control needs to be set to on, Sony BRAVIA Sync, Panasonic Viera Link, Samsung Anynet+, LG SimpLink, and Sharp Aquos Link are some of the names used by the manufactures. You also need One Power set to ON in Settings > System.
on 28-10-2023 15:55
HI juliemc60,
Thank you for your post. I'm sorry to hear about the issue with your Tv box.
Have you been to try the suggestion from roy27?
^Martin
