on 13-05-2023 12:03
I have upgraded my plan multiple times but my hub is quite old, not to mention I suspect it's a bottleneck in the internet speed of connected devices. How would I go about getting a new router? Is it possible to get it for free?
Answered! Go to Answer
on 13-05-2023 12:28
Are you getting the correct download/upload speeds for your package?
If you are then as far as VM are concerned you have the right equipment no matter of its age. The equipment is rented, so if it is still performing to spec they will not replace it.
on 13-05-2023 12:28
on 14-05-2023 17:52
Thanks. I guess if I want better connectivity I can just buy a better router and modem mode the hub. That's how you do it right?
on 14-05-2023 19:08
What plan are you on now? You say the hub is old but which one have you got?
I was on the 350mb service, hadnt upgraded for ages and had the Hub 3 and paying £58 a month. Yes, getting fleeced for being a "loyal" customer, have just upgraded to the 1 GB for an extra £2 a month.
Be careful what you wish for though, my Hub 5 is being a pain atm.
on 15-05-2023 01:57
@FFFluoride wrote:Thanks. I guess if I want better connectivity I can just buy a better router and modem mode the hub. That's how you do it right?
Correct, this is what many of us have done and it allows you to pick a router that suits your needs.
______________________
Scott
My setup: VM TV 360 box, M350 Fibre broadband with Hub 3 in modem mode connected to a Netgear R7000 router. Telewest/VM user since 2001.
