on 08-04-2023 05:51
my broadband slow i contact virgin media few times still slow every time i call is always off shore India Africa Philippine they check is ok for 1 hours, then goes down, i strong fill verginmedia should stop using this country because sometime they cut you off and when you asked to make a complain they not given you a code , it is not easy to talk someone in uk, this company of shore are no good, they known there is a problem with virginmedia but of shore compony they ignore please stop this compony of shore, now they send a tectnician and they charging me £25 if i cancel or reschedule this is
ridiculous when there is a problem with virgin media in uk { please stop using of shore compony }
the Govermment should do something about this.
on 08-04-2023 08:38
Samknows Realspeed
First call 0800 561 0061 - use the automated service to see if there is a local service issue.
Use the test below to see if the issue is at the Hub or device.
Speed test the service to a Router mode Hub(3/4/5) + your device with the link below.
The speed at the Hub should reflect your subscription.
The speed any WiFi device draws data at is limited by its data needs and technical abilities.
