Slow Broadband - Afternoon and evenings
DaveEagles
I have M350 fibre
Can anyone shed any light as to why in the mornings my broadband speed is OK e.g. 215mbps but from around 1500 onwards I get about 30mbps?
There is only my wife and myself connected, no kids gaming etc.
The timings of the slowdown though suggest some capacity issues at certain times of the day.
I've reset the router etc
Thanks in advance
1 ACCEPTED SOLUTION
Accepted Solutions
If it actually is a VM network "capacity" issue causig this it will be evident and show in a BQM - so can you set one up...
Also is this only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check on one to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
Might also be worth checking for any "known issues".  Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
_______________________
Set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then, click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
12 REPLIES 12
Thanks I’ll give the BQM a try
Will take 24h to develop the full picture... post back when you have that image (black out the  ip address).
DaveEagles
The monitor has been running for around 22 hours, it has generated date but I have no idea what this means.Monitor 27-28 Feb.jpg
DaveEagles
Also a gyazo shot of ad hoc speedtests which look a bit haphazard to me
https://gyazo.com/44f718923c82d1428b6da3c51607cc48
OK no evidence of overutiliastion in your area - otherwise it would look like this....
https://community.virginmedia.com/t5/Forum-Archive/Jitter-and-latency/m-p/4609932#M378967
So its probable the issue is due to something specific to you (or a few users)  So to start to pin that down can you say whether your issues are only evident on wifi connections - or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check on one to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
]Lets look at you connection data too - do this.....
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
DaveEagles
Thanks again John,
I'm not sure that I've done what you asked correctly.
I could only see (1) Configure WiFi Network (2) Network Diagnostic Tool and (3) Modify Guest Network.
I selected 2 and got this
Your home network has a few problems.
 Checking Broadband Service
 Checking Ethernet Connections
 Checking WiFi Connections
If you still think something is wrong, please check the following
1              Gateway IPv4 address is valid.
2              Your broadband connection is down.
3              The temperature of your Hub 3.0 is normal.
4              The device 9e:xxxxxxxxxxxx has low signal strength, please move it closer to Hub 3.0.
5              The device 1c: xxxxxxxxxxxx has low signal strength, please move it closer to Hub 3.0.
6              The device 8e: xxxxxxxxxxxx has low signal strength, please move it closer to Hub 3.0.
7              The device 6a: xxxxxxxxxxxx has low signal strength, please move it closer to Hub 3.0.
8              The device 8c: xxxxxxxxxxxx has low signal strength, please move it closer to Hub 3.0.
9              Please place your WiFi device near the Hub 3.0.
I think devices 4 to 8 are phones and IPads and we never notice if response is bad.
My laptop isn't one of the devices above and its connected via WiFi probable 5 metres away with nothing in between the router.
DaveEagles
Sorry I have just realised what info you asked for
Channel               Frequency (Hz) Power (dBmV)  SNR (dB)              Modulation        Channel ID
1              331000000           4.1          38           256 qam               25
2              139000000           2.5          37           256 qam               1
3              163000000           2.5          38           256 qam               4
4              171000000           2.5          37           256 qam               5
5              195000000           2.5          37           256 qam               8
6              203000000           2.2          38           256 qam               9
7              227000000           2.5          38           256 qam               12
8              235000000           2.5          38           256 qam               13
9              243000000           2.7          38           256 qam               14
10           251000000           2.9          38           256 qam               15
11           259000000           3              38           256 qam               16
12           267000000           3.2          38           256 qam               17
13           291000000           3.7          38           256 qam               20
14           299000000           4              38           256 qam               21
15           307000000           4              38           256 qam               22
16           315000000           3.9          38           256 qam               23
17           323000000           4              38           256 qam               24
18           339000000           4.1          38           256 qam               26
19           347000000           4.3          38           256 qam               27
20           355000000           4              38           256 qam               28
21           363000000           4              38           256 qam               29
22           371000000           3.5          38           256 qam               30
23           387000000           3              38           256 qam               32
24           491000000           4.6          38           256 qam               33
Channel               Locked Status    RxMER (dB)        Pre RS Errors      Post RS Errors
1              Locked  38.9        152         88
2              Locked  37.3        1308       97
3              Locked  38.9        317         94
4              Locked  37.6        346         65
5              Locked  37.6        304         87
6              Locked  38.6        334         89
7              Locked  38.6        280         215
8              Locked  38.9        187         177
9              Locked  38.9        172         93
10           Locked  38.9        221         73
11           Locked  38.6        274         88
12           Locked  38.6        158         98
13           Locked  38.6        181         87
14           Locked  38.9        188         110
15           Locked  38.9        120         172
16           Locked  38.6        216         145
17           Locked  38.6        200         70
18           Locked  38.9        228         86
19           Locked  38.6        189         71
20           Locked  38.9        150         91
21           Locked  38.9        176         188
22           Locked  38.9        173         95
23           Locked  38.6        160         92
24           Locked  38.6        232         70
DaveEagles
Channel               Frequency (Hz) Power (dBmV)  Symbol Rate (ksps)         Modulation        Channel ID
1              36600000             42.2        5120       64 qam 11
2              23600000             42.3        5120       64 qam 13
3              30100000             42.3        5120       64 qam 12
4              43099993             42.3        5120       64 qam 10
5              49600019             42.3        5120       64 qam 9
Channel               Channel Type    T1 Timeouts       T2 Timeouts       T3 Timeouts       T4 Timeouts
1              ATDMA                0              0              0              0
2              ATDMA                0              0              0              0
3              ATDMA                0              0              0              0
4              ATDMA                0              0              0              0
5              ATDMA                0              0              2              0
