2 weeks ago
Hi, just received my new router and don't have a wall socket for quick installation. We had virgin before but had tv and broadband. There is no wall socket but just the attached setup. Black cable comes directly in from the outside box then goes into one box then out to a splitter which I assume was for tv and broadband previously.
any ideas if it is possible to setup without having to wait for an engineer?
Answered! Go to Answer
2 weeks ago
@Rory183 wrote:Just either of the two coming out of the splitter? Or disconnect the splitter and use the single on going into there? Don't really want loads of wasted cables around.
Straight into the coax cable coming out of the isolator if you want.
Power levels could be affected, but won't break anything if you try.
2 weeks ago
Plug (screw) the router directly into one of the threaded coax cables.
2 weeks ago
2 weeks ago
2 weeks ago
Thanks I will give that a go now and if not I will re connect it and use one that is coming out of the splitter.
2 weeks ago
All seems to be working. Will check it all properly tomorrow and see if it's better in the splitter coax or as it is
2 weeks ago
If you are getting expected speeds from this site, and your connection is stable, you should be ok:
https://samknows.com/realspeed/
