Wifi pod and hub 5
honeyraith
Hello
I have just installed a new superhub 5 however the WiFi pod isn't working.
Can you please help me?
7 REPLIES 7
Legend
Call the activation number 0800 953 9500, request the VM Pods are paired to the replacement Hub.  For the call have to hand your VM a/c number, the full details from the Hub’s sticker and ALL the VM Pods.
honeyraith
I received a message saying it was activated
I called the number they said that everything has been activated.  Wifi pod still flashing for an hour .
Thanks for coming back to us honeyraith, is your pod still flashing this morning?
Kind Regards,
Steven_L
honeyraith
Yes. Nothing has changed.
Hi Honeyraith 👋.
We would need to look further into this by bringing you in for a private message. Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
honeyraith
Finally hub 5 working with new wifi pod.
Also had to reinstall all passwords etc.
