on 11-10-2023 23:34
I’m using the virgin connect app and when I click on the broadband legend I get the message that I need to optimise my WiFi, I go through a number of steps and it finishes the optimisation but when I go on the broadband legend again it tells me it needs to optimise wifi, it’s so annoying as I am stuck in a loop and I have devices that are paused which I can’t “ unpause”
any help greatly appreciated 👍
yo opt
on 12-10-2023 07:16
Disable MAC filtering to re-enable Paused devices
Login to the Hub's menus at http://192.168.0.1
1) Advanced settings >>> Wireless >>> Security
1.1) then set Wireless MAC Filtering to Disabled
1.2) "Apply changes"
2) Advanced settings >>> Security >>> MAC Filtering
2.1) then delete all entries in the MAC filter list
2.2) Enable Always on
2.3) "Apply changes"
