on 27-10-2023 10:39
LED light on the bottom of my router is showing pink even after rebooting, and my smart tv is now unable to stay connected to bluetooth.
I believe my router is a hub 3
on 27-10-2023 10:44
VM Hub don't support Bluetooth
Is my Hub 3 hot or not ?
It can be the LED is fading or it can an over temperature fault.
Note : Hub 3 in Modem mode has an Magenta LED
To check login in to the Hub 3 menu at http://192.168.0.1/ use the numeric HUB PASSWORD from the bottom side label. ( this is not the Wi-Fi password )
Run the Network diagnostic tool
Scroll down through the results and find the Temperature entry. Is it normal ?
