Packet Loss issue?
ashheron
Hello,
I'm having connection issues for the past few days.
Web pages are seem to be taking a while to load on all devices, missing images etc.. I suspect that it is packet loss causing this, not sure though. Speed test seems to be at advertised speeds.
I've tried resetting the superhub but to no avail.
Here's are my power level stats:
3.0 Downstream channels
14990000007.842QAM 25612
24270000007.942QAM 2563
34350000007.841QAM 2564
44430000007.842QAM 2565
54510000007.842QAM 2566
64590000007.842QAM 2567
74670000007.842QAM 2568
84750000007.842QAM 2569
94830000007.742QAM 25610
104910000007.742QAM 25611
115070000007.842QAM 25613
125150000007.742QAM 25614
135230000007.642QAM 25615
145310000007.442QAM 25616
155390000007.542QAM 25617
165470000007.542QAM 25618
175550000007.742QAM 25619
185630000007.942QAM 25620
195710000007.942QAM 25621
205790000007.642QAM 25622
215870000007.342QAM 25623
225950000007.342QAM 25624
236030000007.442QAM 25625
246110000007.642QAM 25626
256190000007.542QAM 25627
266270000007.342QAM 25628
276350000007.242QAM 25629
286430000007.342QAM 25630
296510000007.242QAM 25631
306590000007.242QAM 25632
316670000007.342QAM 25634
1Locked4200
2Locked4200
3Locked4100
4Locked4200
5Locked4200
6Locked4200
7Locked4200
8Locked4200
9Locked4200
10Locked4200
11Locked4200
12Locked4210
13Locked4200
14Locked4200
15Locked4200
16Locked4200
17Locked4200
18Locked4200
19Locked4200
20Locked4200
21Locked4200
22Locked4200
23Locked4200
24Locked4200
25Locked4200
26Locked4200
27Locked4200
28Locked4200
29Locked4200
30Locked4200
31Locked4200
3.1 Downstream channels
33944K1840QAM 40961108
33Locked437.1576397970
3.0 Upstream channels
04960000041.55120QAM 645
14310000041.35120QAM 646
236600000415120QAM 647
33010000040.85120QAM 648
42360000040.55120QAM 6410
0ATDMA0000
3ATDMA0000
4ATDMA0000
3.1 Upstream channels
1310.436.72KQAM 256
13OFDMA2087400000000
Please help, thanks!
2 REPLIES 2
setup BQM but I think your device might be the problem?
Broadband Quality Monitor | thinkbroadband
or maybe VM DNS run CMD by wire
ping -n 200 1.1.1.1
change your DNS to 1.1.1.1
ashheron
Can't run BQM with the HUB 5 in modem mode unfortunately.
Did a few 200 ping tests to 194.168.4.100, 194.168.8.100, 1.1.1.1 and 8.8.8.8 on my PC with a wired connection to my router, then modem.
Only lost 1 packet overall, although it is around 7am here.
Connection seems to be fine currently, I'll try a ping test if I start having the issue again.
Thanks for the response
