on 29-07-2023 15:53
Hi, I just installed my new Hub 3 today, this is a replacement to my old Virgin router. I followed all instructions and kept waiting for light to go white, but it has been red since I plugged it in and hasn't changed. My WIFI is working, but I'm just not sure why it on constant red light rather than white as stated in the instruction booklet. I read that it could be because it overheating, but I find it odd that it has been like this since I plugged it in. It is brand new out the box.
29-07-2023 16:00 - edited 29-07-2023 16:00
It's rented kit, so you won't always receive a new HUB.
This means it could be faulty 'out of the box'.
on 29-07-2023 16:31
Hi @EEV 👋 Thank you for your post and welcome to the Virgin Media Community 😀
We're sorry to hear about the problem you're experiencing 😔
In the first instance, can you please follow the below steps in the following order:
• Turn the power switch off on the back of the Hub
• Ensure the Hub is upright, in a well-ventilated location, and, if at all possible, out of direct sunlight
• Use the power switch to turn the unit back on
If after following the above steps the router doesn't boot back up after a few minutes, or the red light returns when it does, the router will need replacing.
Regards,
Daniel
on 29-07-2023 16:57
Hi Daniel, followed your instructions, red light still on when I switched back on have WIFI though. Box is warm.
on 29-07-2023 16:58
Didn't know that! I assumed it was a new HUB they were sending me as I upgraded the speed and they said I needed new router.
on 29-07-2023 17:01
Hi @EEV, thank you for your response.
We're sorry to hear that's the case 😔
In order to discuss replacing the router, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
Regards,
Daniel
