on 06-11-2023 13:28
Hi, recently i get virgin media on my new address and i would say it's all good, but i've noticed that internet is dropping connection randomly during a day for like 5-10 seconds and after it's back. It's really annoying becuase i like to play online games and it is still disconnecting me. Also I've noticed that its happen more often on evening when i asssume line is more busy. Tried to reconnect all wires to hub and restarted it few times, but nothing happend.
on 06-11-2023 16:34
Just to be clear as you don't mention it in the text (just title)....
... are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
What Hub model is it? What are the various Hub lights showing/doing when this happens if a Hub3 is the base light a steady white(ish) or flashing green?
on 06-11-2023 17:13
internet is dropping on both wired to pc and on wifi. When internet is gone, light on hub is still static white but on pc it is saying „no internet connection” and after 10 seconds internet is back. That’s the hub3
on 06-11-2023 19:23
Also, today I noticed that if many devices is connected to hub, then it does it more frequently
on 06-11-2023 20:42
Having the same problem as you, Only been with VM for 3 weeks, Ive noticed the hub has been refurbished, so suspect VM send out faulty refurbished hubs.
on 06-11-2023 21:12
@shaq992 wrote:internet is dropping on both wired to pc and on wifi. When internet is gone, light on hub is still static white but on pc it is saying „no internet connection” and after 10 seconds internet is back. That’s the hub3
When there is a network issue the light will flashes green..
Anyways, to nail it can you do this and set up the BQM as soon as...
_________________________________________________________
Post up your Hub/network connection details and someone will check to see if there is a problem there. In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 07-11-2023 10:41
1 | 259000000 | -5.7 | 38 | 256 qam | 16 |
2 | 139000000 | 3.5 | 38 | 256 qam | 1 |
3 | 147000000 | 2.5 | 38 | 256 qam | 2 |
4 | 155000000 | 1.7 | 38 | 256 qam | 3 |
5 | 163000000 | 1 | 38 | 256 qam | 4 |
6 | 171000000 | 0.5 | 38 | 256 qam | 5 |
7 | 179000000 | 0 | 40 | 256 qam | 6 |
8 | 187000000 | -0.5 | 38 | 256 qam | 7 |
9 | 195000000 | -1.2 | 38 | 256 qam | 8 |
10 | 203000000 | -1.7 | 38 | 256 qam | 9 |
11 | 211000000 | -2.4 | 38 | 256 qam | 10 |
12 | 219000000 | -2.7 | 38 | 256 qam | 11 |
13 | 227000000 | -3.2 | 38 | 256 qam | 12 |
14 | 235000000 | -4 | 38 | 256 qam | 13 |
15 | 243000000 | -4.7 | 38 | 256 qam | 14 |
16 | 251000000 | -5 | 38 | 256 qam | 15 |
17 | 267000000 | -6 | 38 | 256 qam | 17 |
18 | 275000000 | -6.4 | 38 | 256 qam | 18 |
19 | 283000000 | -6.4 | 38 | 256 qam | 19 |
20 | 291000000 | -6.5 | 38 | 256 qam | 20 |
21 | 299000000 | -6.4 | 38 | 256 qam | 21 |
22 | 307000000 | -6 | 38 | 256 qam | 22 |
23 | 315000000 | -5.7 | 38 | 256 qam | 23 |
24 | 323000000 | -6.2 | 38 | 256 qam | 24 |
1 | Locked | 38.9 | 0 | 0 |
2 | Locked | 38.9 | 5 | 0 |
3 | Locked | 38.6 | 4 | 0 |
4 | Locked | 38.9 | 0 | 0 |
5 | Locked | 38.9 | 0 | 0 |
6 | Locked | 38.9 | 0 | 0 |
7 | Locked | 40.3 | 0 | 0 |
8 | Locked | 38.9 | 4 | 0 |
9 | Locked | 38.9 | 4 | 0 |
10 | Locked | 38.9 | 4 | 0 |
11 | Locked | 38.9 | 5 | 0 |
12 | Locked | 38.9 | 5 | 0 |
13 | Locked | 38.9 | 13 | 0 |
14 | Locked | 38.9 | 0 | 0 |
15 | Locked | 38.6 | 0 | 0 |
16 | Locked | 38.6 | 0 | 0 |
17 | Locked | 38.9 | 7 | 0 |
18 | Locked | 38.9 | 0 | 0 |
19 | Locked | 38.9 | 5 | 0 |
20 | Locked | 38.6 | 4 | 0 |
21 | Locked | 38.6 | 17 | 0 |
22 | Locked | 38.6 | 5 | 0 |
23 | Locked | 38.6 | 5 | 0 |
24 | Locked | 38.6 | 19 | 0 |
1 | 30100000 | 44.8 | 5120 | 64 qam | 4 |
2 | 23600000 | 43.3 | 5120 | 64 qam | 5 |
3 | 36600000 | 44.8 | 5120 | 64 qam | 3 |
4 | 43100009 | 46.3 | 5120 | 64 qam | 2 |
5 | 49600000 | 47.3 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
on 07-11-2023 10:42
on 07-11-2023 10:43
07/11/2023 10:24:58 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/11/2023 15:19:2 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/11/2023 08:07:42 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/11/2023 08:07:42 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/11/2023 01:40:33 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/11/2023 16:42:13 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/11/2023 11:52:41 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/11/2023 11:52:41 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/11/2023 11:52:39 | Error | DHCP RENEW sent - No response for IPv4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
31/10/2023 05:05:41 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/10/2023 16:22:41 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/10/2023 16:22:41 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/10/2023 03:51:1 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/10/2023 10:25:42 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/10/2023 10:25:42 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/10/2023 04:41:47 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/10/2023 09:19:47 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/10/2023 09:19:47 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
22/10/2023 09:09:58 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/10/2023 21:19:46 | notice | DHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07-11-2023 10:44 - edited 07-11-2023 11:21
