on 28-09-2023 12:57
Since my hub 3 was replaced with a hub 5 I've had constant drops. I'm now on my third hub 5 after having it replaced twice and it's still exhibiting the same issues. It'll drop out for up to a minute a few times an hour. Very frustrating as I'm sure you understand. My wife and I both work at home and have regular meetings that get interrupted. This happens on both wired and wi-fi connections, so not limited to wi-fi. Have a background of 30+ years in IT, so have tried a lot of the normal things. Seen several similar posts on this forum, so I'm thinking I'm not alone.
on 28-09-2023 13:02
1 | 331000000 | 9.1 | 42 | QAM 256 | 25 |
2 | 139000000 | 9.5 | 42 | QAM 256 | 1 |
3 | 147000000 | 9.2 | 42 | QAM 256 | 2 |
4 | 155000000 | 9 | 42 | QAM 256 | 3 |
5 | 163000000 | 9.1 | 42 | QAM 256 | 4 |
6 | 171000000 | 9 | 42 | QAM 256 | 5 |
7 | 179000000 | 8.8 | 42 | QAM 256 | 6 |
8 | 187000000 | 8.8 | 42 | QAM 256 | 7 |
9 | 195000000 | 9.1 | 42 | QAM 256 | 8 |
10 | 203000000 | 9.1 | 42 | QAM 256 | 9 |
11 | 211000000 | 9.2 | 42 | QAM 256 | 10 |
12 | 219000000 | 9.1 | 42 | QAM 256 | 11 |
13 | 227000000 | 8.8 | 42 | QAM 256 | 12 |
14 | 235000000 | 8.6 | 42 | QAM 256 | 13 |
15 | 243000000 | 8.4 | 42 | QAM 256 | 14 |
16 | 251000000 | 8 | 42 | QAM 256 | 15 |
17 | 259000000 | 7.9 | 42 | QAM 256 | 16 |
18 | 267000000 | 8.5 | 42 | QAM 256 | 17 |
19 | 275000000 | 8.7 | 42 | QAM 256 | 18 |
20 | 283000000 | 8.7 | 42 | QAM 256 | 19 |
21 | 291000000 | 8.9 | 42 | QAM 256 | 20 |
22 | 299000000 | 9 | 42 | QAM 256 | 21 |
23 | 307000000 | 8.9 | 42 | QAM 256 | 22 |
24 | 315000000 | 8.8 | 42 | QAM 256 | 23 |
25 | 323000000 | 9.3 | 42 | QAM 256 | 24 |
26 | 339000000 | 8.9 | 42 | QAM 256 | 26 |
27 | 347000000 | 9 | 42 | QAM 256 | 27 |
28 | 355000000 | 8.9 | 42 | QAM 256 | 28 |
29 | 363000000 | 8.8 | 42 | QAM 256 | 29 |
30 | 371000000 | 9 | 42 | QAM 256 | 30 |
31 | 379000000 | 9.2 | 42 | QAM 256 | 31 |
1 | Locked | 42 | 27 | 0 |
2 | Locked | 42 | 37 | 0 |
3 | Locked | 42 | 34 | 22 |
4 | Locked | 42 | 53 | 13 |
5 | Locked | 42 | 55 | 12 |
6 | Locked | 42 | 51 | 18 |
7 | Locked | 42 | 53 | 22 |
8 | Locked | 42 | 47 | 23 |
9 | Locked | 42 | 43 | 17 |
10 | Locked | 42 | 49 | 23 |
11 | Locked | 42 | 45 | 25 |
12 | Locked | 42 | 37 | 14 |
13 | Locked | 42 | 30 | 16 |
14 | Locked | 42 | 29 | 15 |
15 | Locked | 42 | 52 | 52 |
16 | Locked | 42 | 32 | 12 |
17 | Locked | 42 | 39 | 26 |
18 | Locked | 42 | 31 | 14 |
19 | Locked | 42 | 29 | 18 |
20 | Locked | 42 | 40 | 19 |
21 | Locked | 42 | 37 | 14 |
22 | Locked | 42 | 31 | 21 |
23 | Locked | 42 | 49 | 46 |
24 | Locked | 42 | 44 | 26 |
25 | Locked | 42 | 55 | 12 |
26 | Locked | 42 | 30 | 12 |
27 | Locked | 42 | 32 | 17 |
28 | Locked | 42 | 38 | 23 |
29 | Locked | 42 | 48 | 28 |
30 | Locked | 42 | 35 | 22 |
31 | Locked | 42 | 37 | 21 |
0 | 49600000 | 40 | 5120 | QAM 64 | 9 |
1 | 43100000 | 39.3 | 5120 | QAM 64 | 10 |
2 | 36600000 | 39.3 | 5120 | QAM 64 | 11 |
3 | 30100000 | 39 | 5120 | QAM 64 | 12 |
4 | 23600000 | 38.5 | 5120 | QAM 64 | 13 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 3 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 28-09-2023 13:32
Same here...
28-09-2023 15:23:13 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-09-2023 15:23:13 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-09-2023 14:03:41 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-09-2023 14:03:41 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-09-2023 13:01:04 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-09-2023 13:01:04 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-09-2023 10:12:01 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-09-2023 10:12:01 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-09-2023 09:09:43 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-09-2023 09:09:43 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-09-2023 00:46:39 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
28-09-2023 00:46:39 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 01-10-2023 10:48
Hi simster70,
Thank you for your post, welcome to the Community Forums! Sorry to hear you're having some trouble with your broadband service.
I've had a quick look on this end and I can see there are a few signal issues that need ironing out through an engineer visit.
I've sent you a private message so I can get this arranged with you. 😊
on 02-10-2023 08:53
Hi simster70,
Thanks for providing the details via PM.
I've gone ahead and booked an engineer visit for you, to view or change the appointment time, you can manage your booking here.
I just also need to make you aware that there may be a £25 charge for the visit if:
No one is present for the technician visit (aka a missed appointment).
The fault is due to your own equipment.
The fault is due to damage caused by someone at the premises which we were not aware of.
The fault is due to theft, loss, or removal of equipment.
Let us know if you need anything else and how the visit goes.
Thanks!
on 02-10-2023 09:13
Hi Beth,
I can't see when the appointment is for. Can you pm the details?
on 04-10-2023 09:38
Hi @simster70, have you since been able to see the appointment in your online account, or has even the visit since take place?
If you're unsure on when this is taking place, and still need to find out, you're best bet would be to respond to my colleague directly.
David_Bn
on 06-10-2023 09:38
Engineer has been and replaced tightened cables. The cable going into the hub looked and felt kinked, so perhaps that's it? Going to wait a couple of weeks before I confirm all okay.
on 08-10-2023 09:45
Hi @simster70,
Thanks for the update. I'm glad to hear that things appear to be sorted for you now.
Please do let us know if there's anything more that we can help you with.
