on 17-11-2023 21:34
I've been trying to get to my hub 5 settings but I can't due to the password being incorrect I have typed in the right password which is on the bottom of the router for the admin panel but says its incorrect
17-11-2023 22:08 - edited 17-11-2023 22:10
You are using the settings password (underlined red below)?
https://community.virginmedia.com/t5/Forum-Archive/Hub-5-web-interface-password/m-p/4856213#M2934633
Have you reset the hub (on the off-chance you have been given a recycled Hub 5 with another user's settings in place) as per
Resetting the hub will put it back to factory defaults and remove any of your own configuration/settings
on 19-11-2023 19:10
i have used the right password and also did the reset on the router it still says its incorrect
on 19-11-2023 19:22
i have fixed it now i had misread the password the i looked like l on my password
on 21-11-2023 19:49
Hi Kian_Sadler,
We're sorry to hear you had some issues with the password of the hub but super glad to hear things are sorted now.
If you have any further issues, please pop back and let us know.
Many thanks,
