on 29-08-2023 21:42
Hi, all.
Like others, I'm having constant Hub 5 disconnections. It used to happen once a day, sort of, but, today, it's already disconnected 5 times in the last few hours.
Here is the info from Router Status, after I restarted, about 10-15 minutes ago. I'd be grateful for any advice. Thank you.
1 | 139000000 | 4.7 | 42 | QAM 256 | 1 |
2 | 147000000 | 5 | 42 | QAM 256 | 2 |
3 | 155000000 | 4.9 | 42 | QAM 256 | 3 |
4 | 163000000 | 5.1 | 42 | QAM 256 | 4 |
5 | 171000000 | 4.7 | 43 | QAM 256 | 5 |
6 | 179000000 | 4.8 | 43 | QAM 256 | 6 |
7 | 187000000 | 5 | 43 | QAM 256 | 7 |
8 | 195000000 | 4.7 | 43 | QAM 256 | 8 |
9 | 203000000 | 4.9 | 43 | QAM 256 | 9 |
10 | 211000000 | 5.1 | 43 | QAM 256 | 10 |
11 | 219000000 | 4.9 | 43 | QAM 256 | 11 |
12 | 227000000 | 5 | 43 | QAM 256 | 12 |
13 | 235000000 | 4.8 | 43 | QAM 256 | 13 |
14 | 243000000 | 4.7 | 43 | QAM 256 | 14 |
15 | 251000000 | 4.5 | 43 | QAM 256 | 15 |
16 | 259000000 | 4.2 | 42 | QAM 256 | 16 |
17 | 267000000 | 4.9 | 43 | QAM 256 | 17 |
18 | 275000000 | 5 | 42 | QAM 256 | 18 |
19 | 283000000 | 4.9 | 43 | QAM 256 | 19 |
20 | 291000000 | 5.5 | 43 | QAM 256 | 20 |
21 | 299000000 | 5.5 | 43 | QAM 256 | 21 |
22 | 307000000 | 5.5 | 43 | QAM 256 | 22 |
23 | 315000000 | 5.5 | 43 | QAM 256 | 23 |
24 | 323000000 | 5.4 | 43 | QAM 256 | 24 |
25 | 331000000 | 5.6 | 43 | QAM 256 | 25 |
26 | 339000000 | 5.6 | 41 | QAM 256 | 26 |
27 | 347000000 | 5.4 | 43 | QAM 256 | 27 |
28 | 355000000 | 5.6 | 43 | QAM 256 | 28 |
29 | 363000000 | 5.4 | 43 | QAM 256 | 29 |
30 | 371000000 | 5.1 | 43 | QAM 256 | 30 |
31 | 379000000 | 5.4 | 43 | QAM 256 | 31 |
1 | Locked | 42 | 28704 | 152091 |
2 | Locked | 42 | 44534 | 55710 |
3 | Locked | 42 | 115269 | 17466 |
4 | Locked | 42 | 18295 | 3295 |
5 | Locked | 43 | 13012 | 5171 |
6 | Locked | 43 | 14696 | 5738 |
7 | Locked | 43 | 33843 | 23135 |
8 | Locked | 43 | 24965 | 1622 |
9 | Locked | 43 | 22578 | 731 |
10 | Locked | 43 | 17734 | 397 |
11 | Locked | 43 | 11593 | 240 |
12 | Locked | 43 | 6349 | 114 |
13 | Locked | 43 | 5401 | 70 |
14 | Locked | 43 | 5139 | 60 |
15 | Locked | 43 | 4255 | 23 |
16 | Locked | 42 | 4315 | 27 |
17 | Locked | 43 | 3531 | 5 |
18 | Locked | 42 | 3091 | 1 |
19 | Locked | 43 | 2824 | 3 |
20 | Locked | 43 | 2153 | 0 |
21 | Locked | 43 | 1718 | 0 |
22 | Locked | 43 | 1263 | 1 |
23 | Locked | 43 | 788 | 0 |
24 | Locked | 43 | 748 | 0 |
25 | Locked | 43 | 623 | 0 |
26 | Locked | 41 | 485 | 0 |
27 | Locked | 43 | 578 | 0 |
28 | Locked | 43 | 416 | 0 |
29 | Locked | 43 | 358 | 0 |
30 | Locked | 43 | 416 | 0 |
31 | Locked | 43 | 288 | 0 |
0 | 49600000 | 49.3 | 5120 | QAM 64 | 1 |
1 | 43100000 | 48.8 | 5120 | QAM 64 | 2 |
2 | 36600000 | 48 | 5120 | QAM 64 | 3 |
3 | 30100000 | 48.8 | 5120 | QAM 64 | 4 |
4 | 23600000 | 47.5 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 10 | 1 |
1 | ATDMA | 0 | 0 | 9 | 1 |
2 | ATDMA | 0 | 0 | 9 | 1 |
3 | ATDMA | 0 | 0 | 10 | 1 |
4 | ATDMA | 0 | 0 | 9 | 1 |
29-08-2023 23:37:12 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:35:48 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:33:13 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:33:09 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:32:33 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:31:28 | warning | MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:29:53 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:24:21 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:24:21 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:23:46 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:23:46 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:22:32 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:22:32 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:22:27 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
29-08-2023 23:22:26 | warning | TCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:21:32 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:21:32 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:21:32 | warning | Dynamic Range Window violation |
29-08-2023 23:21:27 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:21:15 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:21:13 | notice | Honoring MDD; IP provisioning mode = IPv4 |
29-08-2023 23:20:56 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:17:41 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 23:05:22 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 22:48:54 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
29-08-2023 22:48:54 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 01-09-2023 13:21
Hi @mrq2022 👋.
Thanks for reaching out to us. Apologies you are having issues with the performance of your hub. We can certainly assist you, we would need to bring you in for a private message to discuss this and resolve.
Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
01-09-2023 13:30 - edited 01-09-2023 13:31
If the Errors are still mounting up this is a service fault across all the downstream channels.
