on 26-12-2023 23:07
Hello, I have a Hub 3 which is displaying a continuous red light and is warm to the touch. Scanning my connection via the Virgin Media shows no faults in my area or on my network. Obviously a red light where a yellow light has always been present does indicate an issue. Have checked that all cable connections are right but still have the issue. Does the Hub need replacing or is there an alternative solution?
on 27-12-2023 09:00
Login to the Hub menu http://192.168.0.1/ , run the Network diagnostic tool
Scroll down through the results to Temperature - is it Normal ?
on 27-12-2023 09:02
Hey debaj, thank you for reaching out and I am so sorry to hear this.
I am going to send you a PM but please can you try these steps for us;
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
Please look out for my PM.
Matt - Forum Team
New around here?
on 28-12-2023 12:20
Glad we have managed to get this resolved for you 🙂
Matt - Forum Team
New around here?
