on 22-12-2023 21:23
My hub 3 has a constant solid Red power light, I have read the help page on the Virgin website and several posts on the forum which suggests the hub is overheating or in modem mode.
I can confirm that it is in router mode, well ventilated and I have tried to reboot the hub several times but the light stays solid Red.
More recently I have also noticed the WiFi drops out randomly for no obvious reason, virgin report a good connection in the local area.
Does this indicate a fault with the hub?
Answered! Go to Answer
on 27-12-2023 17:25
The engineer came today, took one look listened to what has happened and replaced it with a Hub 5.
All going well so far, fingers crossed.
on 23-12-2023 08:15
Hi @allyq02
Apologies for any broadband issues but thanks for letting us know about the red light.
You need a tech visit so I'll send you a PM now to assist further.
on 23-12-2023 23:32
Mine has been getting redder for months, I'm sure its just the LED aging badly. It's a bi-colour LED that shows red and green i think? The green side is aging and getting dimmer as time goes on. It used to be an off white (a combination of the green and red), and has been going orange and is now red. I don't think its an issue at all.
on 26-12-2023 13:31
Hey @breadbox1,
With hour Hub lights, on the 3 the lights can Dim over time with continued use, with this what we would ask is for you to perform a full reboot of your equipment, once the Hub is back online can you confirm back to us if the light remains red.
Joe
on 26-12-2023 20:16
It could be just the LED failing over time as the hub does work ok most of the time except for WiFi dropping out intermittently.
John_GS has already arranged a technician visit so I will see what they say and post the outcome.
on 26-12-2023 20:21
It could just be a LED issue, we have a technician booked to visit so they can check if it's that or something more serious.
We have tried rebooting it and resetting it several times and the LED stays a constant bright Red.
The WiFi drops more often recently but I suppose that could be for all sorts of reasons.
on 27-12-2023 17:25
