on 01-10-2023 15:12
Hi, Virgin have just replaced a broken hub with the 3.0 model. I put it in modem mode as with the last one to connect to the existing wifi router but there was no internet connection from the latter. It took me a while to realize that this was because the cable between the two was plugged into port 4 on the hub and it only started working after switching to port 1. Is this known, noted anywhere? I didn't try the other two ports.
Answered! Go to Answer
on 03-10-2023 15:21
Hi nz
Thanks for your post, welcome to the Community Forums.
I'm so sorry if you have been advised otherwise, however yes - only port one on every Hub model will work in modem mode. Wireless communications are also turned off.
If you have anymore questions for us, please don't hesitate to ask 😊
on 03-10-2023 15:21
Hi nz
on 03-10-2023 17:10
Its possible VM know something we don't about wired connected devices that that some NIC don't link up and that VM makes each port with given code for the link to work. Or just bad coding of the link negotiation either on the hub or device. With the hub 3 any one port will work
on 14-10-2023 22:11
Thanks, I won't need to experiment with the other ports. I haven't been advised otherwise, or at all. Is this noted anywhere publicly available?
