on 26-09-2023 17:37
Can someone advise on how to get my broken outdoor connection box repaired? The external cover ( which was never securely fixed) has cracked and is now in two pieces leaving wires exposed.
on 28-09-2023 18:40
Hi Murphy7519,
This is something we can certainly check for you but in order to do that I will need to confirm some information with you to pass security.
I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
on 28-09-2023 19:34
Hi Murphy7519,
Thanks for sticking with me via private message.
We're glad the visit has been booked for you. If you have any further issues, pop back and let us know.
Many thanks,
