on 05-05-2023 11:53
Continuous loud crackling on my landline on both outgoing/incoming calls. New batteries inserted and phone charged, no obstruction on phone & wiring all ok. Never experienced any previous probs. Area code per VM clean. One line, 3 phones, 2 downstairs & 1 upstairs all displaying the same crackling issue.
Answered! Go to Answer
on 05-05-2023 12:00
Hello jimc8982
Sorry to hear of the landline issues experienced, we appreciate the frustration and you taking the time to raise this via the forums.
Are you using the landline via a wall socket or the back of the Hub? If it is a wall socket, does it do the same with the phone connected to other wall sockets? If so, do you have an alternate handset you can try to eliminate this being the issue?
Rob
on 05-05-2023 12:00
Hello jimc8982
Rob
on 05-05-2023 19:22
My base station is downstairs in the hall (via a wall socket), an extension from this in the sitting room and a further extension upstairs in the master bedroom. I moved everything around to check all extensions/wall sockets etc with the same crackling noise (like treading on broken glass) occurring on all phones when phoning out or receiving an incoming call. All phones display a message "phone line needs checked". To a layman like myself this looks like a visit from a phone technician is required.
How do I contact VM to request a technician (it was VM who installed the sockets) for a home visit.
on 05-05-2023 19:44
Thanks for coming back to us @jimc8982.
I'd be happy to take a closer look into this for you.
Check out the envelope in the top right hand corner for a private message from me.
Kindest regards,
David_Bn
