3 weeks ago
Hi There,
Hope someone can help. We have recently set up a new Virgin Media Hub 5 and all seems to be be fine apart from I can’t connect my Worcester Bosch EasyControl (for the combi boiler) to it. The EasyControl was working fine with the previous VM hub (not a Hub 5). I’ve followed the reset directions from the WB website for the EasyControl, but it can’t find the WiFi network despite symbols showing it is searching for it. Says “No WiFi connection. The WiFi signal for the WiFi router may be too weak. install a WiFi amplifier. See photo. Thanks in advance for your help. I’m not at all technical by the way.
Answered! Go to Answer
3 weeks ago
In similar situation people have made progress by disabling the 5GHz Wi-Fi from the VM Hub 5 (for a period),
to ensure the mobile phone app and the boiler are both on the 2.4GHz band when attempting to set up the connection.
3 weeks ago
3 weeks ago
3 weeks ago
Thank you Client62. I’ll give that a go. 👍
