2 weeks ago
Recently noticed download speeds slower then normal - no problems showing in my area:
1 | 203000000 | 5.8 | 40 | 256 qam | 9 |
2 | 139000000 | 6 | 38 | 256 qam | 1 |
3 | 147000000 | 5.8 | 40 | 256 qam | 2 |
4 | 155000000 | 5.9 | 40 | 256 qam | 3 |
5 | 163000000 | 5.9 | 40 | 256 qam | 4 |
6 | 171000000 | 6 | 40 | 256 qam | 5 |
7 | 179000000 | 6 | 40 | 256 qam | 6 |
8 | 187000000 | 5.9 | 40 | 256 qam | 7 |
9 | 195000000 | 5.8 | 40 | 256 qam | 8 |
10 | 211000000 | 5.8 | 40 | 256 qam | 10 |
11 | 219000000 | 5.8 | 40 | 256 qam | 11 |
12 | 227000000 | 5.6 | 40 | 256 qam | 12 |
13 | 235000000 | 5.5 | 40 | 256 qam | 13 |
14 | 243000000 | 5.5 | 40 | 256 qam | 14 |
15 | 251000000 | 5.5 | 40 | 256 qam | 15 |
16 | 259000000 | 5 | 40 | 256 qam | 16 |
17 | 267000000 | 4.9 | 40 | 256 qam | 17 |
18 | 275000000 | 5 | 40 | 256 qam | 18 |
19 | 283000000 | 5.8 | 40 | 256 qam | 19 |
20 | 291000000 | 6.1 | 40 | 256 qam | 20 |
21 | 299000000 | 6.6 | 40 | 256 qam | 21 |
22 | 307000000 | 6.5 | 40 | 256 qam | 22 |
23 | 315000000 | 6.5 | 40 | 256 qam | 23 |
24 | 323000000 | 6.5 | 40 | 256 qam | 24 |
1 | Locked | 40.3 | 11 | 0 |
2 | Locked | 38.9 | 72 | 0 |
3 | Locked | 40.9 | 55 | 0 |
4 | Locked | 40.3 | 36 | 0 |
5 | Locked | 40.9 | 26 | 0 |
6 | Locked | 40.9 | 17 | 0 |
7 | Locked | 40.3 | 9 | 0 |
8 | Locked | 40.9 | 6 | 0 |
9 | Locked | 40.9 | 14 | 0 |
10 | Locked | 40.3 | 4 | 0 |
11 | Locked | 40.9 | 9 | 0 |
12 | Locked | 40.9 | 7 | 0 |
13 | Locked | 40.3 | 7 | 0 |
14 | Locked | 40.3 | 11 | 0 |
15 | Locked | 40.9 | 13 | 0 |
16 | Locked | 40.9 | 12 | 0 |
17 | Locked | 40.3 | 6 | 0 |
18 | Locked | 40.3 | 8 | 0 |
19 | Locked | 40.3 | 9 | 0 |
20 | Locked | 40.3 | 7 | 0 |
21 | Locked | 40.3 | 11 | 0 |
22 | Locked | 40.3 | 7 | 0 |
23 | Locked | 40.9 | 19 | 0 |
24 | Locked | 40.3 | 22 | 0 |
2 weeks ago
1 | 23600000 | 44.3 | 5120 | 16 qam | 5 |
2 | 36600000 | 43.8 | 5120 | 64 qam | 3 |
3 | 30100000 | 43.5 | 5120 | 64 qam | 4 |
4 | 43100000 | 44.3 | 5120 | 64 qam | 2 |
5 | 49600000 | 44.8 | 5120 | 64 qam | 1 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 6 | 0 |
2 weeks ago
13/04/2024 00:44:20 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/04/2024 22:57:21 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:45 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/04/2024 22:51:35 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/04/2024 22:37:1 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/04/2024 01:54:48 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
10/04/2024 00:08:2 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2024 13:01:5 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/04/2024 12:08:2 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/04/2024 02:18:41 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/04/2024 00:08:2 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/03/2024 13:43:7 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/03/2024 11:08:2 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/03/2024 23:40:19 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/03/2024 23:08:2 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/03/2024 20:46:27 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
23/03/2024 11:08:2 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/03/2024 18:41:16 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/03/2024 23:08:2 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/03/2024 20:32:55 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
2 weeks ago
2 weeks ago
Any help from Virgin or anyone's opinion?
2 weeks ago
Anyone?
2 weeks ago - last edited 2 weeks ago
Stats look good to me (save for channel 1 upstream qam which is too low) and BQM is okay if a little saw-shaped (do you have a Hub 5x?). Check again for local faults on 0800 561 0061 and try a full power down of the hub for a few minutes.
2 weeks ago
Hi @Cardiffman282
It's a hub 3, that 1 channel has gone back to 64 for the moment at least. I've tried powering it down for a few minutes.
Is it normal to have lots of little packet loss episodes?
2 weeks ago
The packet loss in the BQM looks negligible. Coming back to the original query you really need to use an ethernet cable connection to run a proper speed test.
2 weeks ago
Hi @Ninko
Welcome back to our community forums and sorry to hear you have been having issues with your service speeds. We can understand the inconvenience caused and we want to best. To best look into this, I have sent you a private message. Please keep an eye out for an envelope at the top right corner of your Forum page. Let me know if you have any issues locating this.
