on 05-10-2023 13:52
Hi I’m posting for the 3rd time. I keep getting told I’m posting to moderators but no instructions where to post. Hopefully I’m on the right forum now. I have installed a ring doorbell system but the WiFi signal is very poor so I was wondering can I order a WiFi booster to boost the signal as everything is connected to the same mains supply. I have both Virgin and o2 volt contracts, any help greatly appreciated . If this is the wrong forum could someone give me a link to the correct one.
Answered! Go to Answer
on 05-10-2023 14:52
This is the correct forum and a VM person will respond when they get here in a day or two.
In the meantime see this....
Do you know if its a wifi only issue (are ethernet connected devices ok?), may be - as doorbells seem very prone to dropping out. if it is - then On a Hub3/4/5, you could first try separating the SSID's of the 2.4 and 5 GHz wifi bands by renaming them in the settings At the same time switch off "channel optimisation/Smart wifi” and “ apply and save the settings. All wifi devices will now need reconnecting to the best SSID at each location. Also use a wifi scanning App to find the best wifi channels to use (just select and use channels 1,6,11 on 2.4GHz) - this often helps Hub users get better wifi performance particularly on ring doorbells - so its worth trying - but its still no substitute for getting better kit 🙂
To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless and poor value “boosters”). However, their Pods are only free to customers on the 1GB, Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you. VM Wifi is now “guaranteed” to 30 Mbps/room it’s now called… Wifi Max
You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible - you are - it is clearly stated on the webpage.
Note that Pods wont work if you have renamed the SSID's - as above - you would have to revert back.
If not free to you… you will be charged £8/month for up to 3 pods (note - BT charge £10/mo for their whole home wifi solution). It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point, (4) a pair of good quality Wifi Powerline Adaptors, or a combination of (2&3).
£40-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage. Spend more for additional advanced“features” - if required.
See message 5 in this thread for how to connect Pods
https://community.virginmedia.com/t5/Networking-and-WiFi/WiFi-boosters-needed/m-p/5122436#M497217
on 05-10-2023 14:52
on 07-10-2023 15:04
Hi @Cabo55,
Thank you for your post and welcome back to our community forums. We're here to help.
I can see that one of my colleagues has already responded to you regarding your Wi-Fi related query here via the other thread that you made about it. We'll continue to assist you with this matter from there going forward.
