Superhub 5 - Wifi Pods
nathan_zetec
Up to speed
Have recently upgraded to gig1 and been supplied a superhub 5, to replace my superhub 3.
The speeds are fantastic. In one room.
The wifi pods I had previously will not connect. I have spoken to helpdesk twice, with solutions ranging from leave them 2 - 5 hours, to try WPS pair, to reset the SSID, full factory reset
Please can someone help?
1 REPLY 1
The Pods and Hub may not be activated correctly on your account.
Call the equipment activation number on - 0800 953 9500 (follow options) –see if they can sort it.
You will need the Model numbers, serial numbers/MAC addresses off the barcode stickers of ALL pieces of kit and also your account number
