on 27-09-2023 22:16
Hust switched to virgin and have been sent a Hub 3, so far i cant connect my Sonos One. Ive seen other people have had this issue but couldnt see any sure fire fixes
Im thinking if i switch my hub 3 to modem mode and get a separate router would that fix the issue ?
Answered! Go to Answer
on 30-09-2023 18:18
So this is not a connectivity issue to do with Wi-Fi or network cables. Only now we discover this !
In the Virgin Media online account, find the section WebSafe and TURN OFF both "Child Safe" and "Virus Safe"
If you are unable to do this, set the Sono One to use a Public DNS E.G. Google DNS 8.8.8.8 and 8.8.4.4 this will bypass the effects of Child Safe and Virus Safe which are DNS content filters.
on 28-09-2023 07:53
We have a HUB 3 in Router mode, it is not noted for having Wi-Fi compatibility issues.
Have you reset the Sonos One and followed the makers installation instructions to the letter ?
on 30-09-2023 11:46
Hi there @Slimbo
I am so sorry that you are facing these issues with your services and thank you again for posting. Can I ask if you are facing any other connection issue with other devices? Can I also ask if you have followed the instructions as Client62 has mentioned.
on 30-09-2023 12:00
Hi yes, ive tried resetting the router and Sonos. Have tried setting up wireless and via ethernet cable but cant get it to work. Tried setting up at a friends house to check it wasnt the sonos and it worked fine.
on 30-09-2023 18:18
on 05-10-2023 07:19
Thanks, worked perfectly.
If only the virgin tech support or sonos support knew how to sort.
on 07-10-2023 08:17
Hi @Slimbo,
Thank you for the update on this. I'm glad to hear that this has now been addressed and resolved.
Please do let us know if there's anything more that we can help you with.
