on 07-07-2023 12:21
Please help. My router has a solid red light and no others. Internet works fine.
I have rebooted and also reset (pin hole) but no change.
any ideas?
Answered! Go to Answer
on 11-07-2023 12:24
Thanks for all your help. New router installed and all working fine again. Thanks MollyT
on 07-07-2023 13:03
amall123,
Mine is the same! I noticed it earlier in the year after reading an article on the web that said the red light on VM Routers was a warning that it is overheating and in extreme circumstances may catch fire! I contacted VM Support who said it is nothing to worry about, all hunky dory just the LED ageing? Anyone else been told the same.
Regards,
Ron.
on 07-07-2023 13:10
Hi Amall123 👋 welcome to the community! Thank you for posting.
Sorry to hear about these concerns regarding a red light on your hub - thank you for confirming you have tried a reboot and a reset and this has not fixed it!
I'm just going to pop you a PM to confirm a few account details so we can take a closer look and send out a replacement or an engineer if needed. You can find the PM in the top right corner of the page in your Inbox. 📩 We can then return to this public thread with another update when possible. Thank you for your patience in the meantime!
Wishing you all the best. 🌞
on 11-07-2023 12:24
on 11-07-2023 14:21
That is great to hear amall123.
Please do reach out if we can assist in the future.
