Problems with dropouts
MimosaRages
I keep getting wifi dropouts that happen sporadically throughout the day for the past 6 weeks. This affects general internet and zoom calls. I'm posting my logs below, can anyone spot anything wrong? When I run a diagnostic it tells me I have broadband issues but doesn't say anything else.
51707500006.543.4QAM2565
61787500006.843.4QAM2566
71867500006.743.4QAM2567
81947500006.543.4QAM2568
92027500006.443.4QAM2569
102107500006.344.6QAM25610
112187500006.343.4QAM25611
122267500005.940.9QAM25612
132347500006.240.9QAM25613
142427500006.343.4QAM25614
152507500005.940.9QAM25615
162587500006.140.4QAM25616
172667500005.940.9QAM25617
182747500005.940.4QAM25618
192827500005.440.9QAM25619
202907500005.640.9QAM25620
212987500005.940.4QAM25621
223067500006.140.9QAM25622
233147500005.940.4QAM25623
243227500005.640.4QAM25624
253307500005.440.4QAM25625
263387500005.740.4QAM25626
273467500005.840.4QAM25627
283547500005.840.4QAM25628
293627500005.540.4QAM25629
303707500005.340.4QAM25630
313787500005.440.9QAM25631
323867500005.140.4QAM25632
333947500005.440.4QAM25633
34402750000540.4QAM25634
354107500005.140.4QAM25635
3.0 Downstream channels
5Locked43.37659100
6Locked43.37659100
7Locked43.37659100
8Locked43.37659100
9Locked43.37659100
10Locked44.62597700
11Locked43.37659100
12Locked40.94620900
13Locked40.94620900
14Locked43.37659100
15Locked40.94620900
16Locked40.36628700
17Locked40.94620900
18Locked40.36628700
19Locked40.94620900
20Locked40.94620900
21Locked40.36628700
22Locked40.94620900
23Locked40.36628700
24Locked40.36628700
25Locked40.36628700
26Locked40.36628700
27Locked40.36628700
28Locked40.36628700
29Locked40.36628700
30Locked40.36628700
31Locked40.94620900
32Locked40.36628700
33Locked40.36628700
34Locked40.36628700
35Locked40.36628700
3.1 Downstream channels
1591304K2511QAM2048417
159Locked423.81264380
Thanks in advance
Mimi
2 REPLIES 2
Post up the data from the upstream channels and the network logs.
Also, are your issues only evident on wifi connections or do you see them at the same times on devices connected on ethernet cables? If you don't know, can you check to help diagnose whether it is just a wifi issue or it could be network connection/Hub related?
Sabrina_B
Hi @MimosaRages 👋.
Thanks for reaching out to us and welcome to the Community Forums. Apologies for the issues that you are having, the logs that you have submitted are true to the Virgin Network diagnostics, but if you are using the Hub in modem mode what you are experiencing and the log reports will not be true. We would advise to look into removing any third party equipment and using the Hub in router mode to see if you are having issues, if you are having signal related issues due to location of devices in the home from the Hub, you can look into our 👉 WiFi Max that we have to improve signal strength and speeds.
If you wish to carry on using a third party device you may think about using it in router mode and following on from the Virgin network name as modem mode and the compatibility with firmware will hinder the Hubs performance. As for compatibility of the hardware, if your third party Hub is WiFi 6 enabled then it will not work on Hub 3's or 4's.
If you are still facing issues, we can look into this further via private message. Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
Thanks.
Sabrina
