on 04-02-2024 20:16
My wifi connection will lost and reconnect everyday starting from 4pm to 9pm
All device in my home will lost its wifi connection
Somethimes the situation will continue until mid night
Tried to run the kit test but it keeps telling me that everythings is good
Please help
Thank you
on 04-02-2024 20:25
Create a BQM here and post the live link.
Sounds like oversubscription.
on 04-02-2024 20:45
https://www.thinkbroadband.com/broadband/monitoring/quality/share/460e736e64174bbe726f4857cd898a133ac25644
Is this what you mean a BQM?
on 04-02-2024 20:47
@lok800guitar wrote:https://www.thinkbroadband.com/broadband/monitoring/quality/share/460e736e64174bbe726f4857cd898a133ac25644
Yes.
Well, easier access:
on 05-02-2024 16:55
No evidence of over-subscription issues there.. its all the same across 24h - looks very good apart from what looks like a red fringe of dropped packets.
What happens on an ethernet cable connected devive between those hours? If you dont know test it tonight and report back. If they are ok then it might just be a case of wifi interference at that time - many reasons why that could occur
on 05-02-2024 17:10
Hello
I connected most of the device via ASUS wifi router
The ASUD router is the only device connected via cable.
When the sitation happen, the ASUS wifi connection is still valid. It shows connected but can't access to internet.
And I tried connected to the wifi of the Virgin Media hub ( I just sat next to the hub ), the signal is strong. And it frustrated between connected and connected but can't access to the internet
My wife is a streamer, during peak hour, her streaming was frozen. She suffered alot in this situation.
And streaming of youtube, Netflix, Disney were affected, too.
It has been more than half a year and finally I decided to ask in the forum
on 05-02-2024 17:26
What model of Asus router are you using?
What Hub model do you have and is it in modem only mode? If so there should be no wifi from the VM Hub - it all comes from the Asus.
Can you try setting it all up again as per Tudor’s message 2 in here….
https://community.virginmedia.com/t5/Networking-and-WiFi/Hub3-in-Modem-mode/td-p/5206738
on 05-02-2024 17:36
I will set it according to what you've told me
Before that, I forgot to mention that my Hub will restore to factory default after certain days/weeks
All SSIS and password will be gone
Is this normal?
on 05-02-2024 18:24
I set up again according to Tudor's message
Will try that again tomorrow
My wife stop the streaming now and she is really mad now
She will try that again tomorrow
on 06-02-2024 18:37
Hello
ASUS AC68U is the router I am using
I set it up again according to the post
My wife start streaming an hour ago
But nothing changed. Its screen still freezed
I did a speed test via VM page
This is the result
I am using M500 package but I don't think this is up to speed
Please advice.
Thank you
