2 weeks ago
On Monday 1st April, the internet was down for everyone in my postcode, it came back on 2nd April at around noon but since then my internet has been randomly cutting out on my PC every few minutes which is connected directly to the Hub4 router via ethernet cable. The task bar in the bottom right does not say I have lost connection to the internet or anything but games and apps such as Discord fully freeze up/cut out so I am definitely getting 100% packet loss or fully losing connection.
I've attached two clips showing my issue below, please see the links below, if you aren't familiar with this game it may be a little hard to follow but you can see me lose connection, the characters either freeze or continue to walk in one direction before teleporting to where they're supposed to be. (You can see a red square with a warning symbol in it on the left in the first clip at around 0:04 seconds as well as a lightning bolt symbol which I know means bad/lost connection to the server and at 0:05 there is an icon on the left with 3 orange rectangles that signify packet loss. Same for the second clip.
This happens literally every few minutes:
https://streamable.com/sjnst7
I've shared my experience both in this forum and on the Virgin Media subreddit over the past couple of weeks but haven't been able to fix the issue I am facing. I will provide my Broadband Quality Monitor below but I don't think the issues are represented on there somehow.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/0c17ac529c00d48229d05cbf74cafcee34...
I have factory reset my router multiple times since the problems started occuring and even bought a brand new ethernet cable yesterday and even with both of these things taken into account I'm getting the same issues still. I'm thinking about purchasing a brand new coaxial cable too just to be fully sure it's not any of my own equipment.
I had ZERO issues prior to the maintenance in my area on April 1st and there isn't any more maintenance scheduled for my area so I'm not sure what's happening. One thing that may be of note or just some strange coincidence is that about a week after the issues started, there was an electric power outage in my area and once the electricity came back on for everyone my internet was actually perfectly fine for about a day before returning to my previous problems.
It's been 18 days now and I'm still having issues, any advice of any sort would be very much appreciated and I'd be more than happy to give any further info that is required.
Thank you very much everyone.
2 weeks ago
That's an unusual BQM. The latency is pretty good with few significant delays BUT with a constant low level of lost packets.
These could be the cause of your gaming problems.
It would be useful to see your upstream and downstream and router logs.
2 weeks ago
Hi there,
Thank you very much for the help, please see below upstream, downstream and router logs.
(may have to send across multiple replies)
25 | 331000000 | 0.900002 | 38.605377 | QAM256 | 25 |
1 | 139000000 | 4.199997 | 38.605377 | QAM256 | 1 |
2 | 147000000 | 3.799999 | 38.605377 | QAM256 | 2 |
3 | 155000000 | 3.799999 | 38.605377 | QAM256 | 3 |
4 | 163000000 | 3.299999 | 38.605377 | QAM256 | 4 |
5 | 171000000 | 3.000000 | 38.605377 | QAM256 | 5 |
6 | 179000000 | 2.799999 | 38.983261 | QAM256 | 6 |
7 | 187000000 | 2.900002 | 38.983261 | QAM256 | 7 |
8 | 195000000 | 2.700001 | 38.983261 | QAM256 | 8 |
9 | 203000000 | 2.599998 | 38.605377 | QAM256 | 9 |
10 | 211000000 | 2.599998 | 38.605377 | QAM256 | 10 |
11 | 219000000 | 2.799999 | 38.983261 | QAM256 | 11 |
12 | 227000000 | 2.799999 | 38.983261 | QAM256 | 12 |
13 | 235000000 | 2.799999 | 38.983261 | QAM256 | 13 |
14 | 243000000 | 2.599998 | 38.605377 | QAM256 | 14 |
15 | 251000000 | 2.599998 | 38.605377 | QAM256 | 15 |
16 | 259000000 | 2.799999 | 38.605377 | QAM256 | 16 |
17 | 267000000 | 2.799999 | 38.983261 | QAM256 | 17 |
18 | 275000000 | 2.599998 | 38.983261 | QAM256 | 18 |
19 | 283000000 | 2.200001 | 38.983261 | QAM256 | 19 |
20 | 291000000 | 2.099998 | 38.983261 | QAM256 | 20 |
21 | 299000000 | 2.000000 | 38.983261 | QAM256 | 21 |
22 | 307000000 | 1.799999 | 38.605377 | QAM256 | 22 |
23 | 315000000 | 1.400002 | 38.605377 | QAM256 | 23 |
24 | 323000000 | 1.099998 | 38.983261 | QAM256 | 24 |
26 | 339000000 | 0.900002 | 38.983261 | QAM256 | 26 |
27 | 347000000 | 0.900002 | 38.605377 | QAM256 | 27 |
28 | 355000000 | 0.599998 | 38.983261 | QAM256 | 28 |
29 | 363000000 | 1.000000 | 38.983261 | QAM256 | 29 |
30 | 371000000 | 1.099998 | 38.983261 | QAM256 | 30 |
31 | 379000000 | 1.200001 | 38.605377 | QAM256 | 31 |
32 | 387000000 | 1.200001 | 38.983261 | QAM256 | 32 |
25 | Locked | 38.605377 | 0 | 0 |
1 | Locked | 38.605377 | 0 | 0 |
2 | Locked | 38.605377 | 0 | 0 |
3 | Locked | 38.605377 | 0 | 0 |
4 | Locked | 38.605377 | 0 | 0 |
6 | Locked | 38.983261 | 0 | 0 |
7 | Locked | 38.983261 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.605377 | 0 | 0 |
10 | Locked | 38.605377 | 0 | 0 |
11 | Locked | 38.983261 | 0 | 0 |
12 | Locked | 38.983261 | 0 | 0 |
13 | Locked | 38.983261 | 0 | 0 |
14 | Locked | 38.605377 | 0 | 0 |
15 | Locked | 38.605377 | 0 | 0 |
16 | Locked | 38.605377 | 0 | 0 |
17 | Locked | 38.983261 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.983261 | 0 | 0 |
22 | Locked | 38.605377 | 0 | 0 |
23 | Locked | 38.605377 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 38.983261 | 0 | 0 |
27 | Locked | 38.605377 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.983261 | 0 | 0 |
31 | Locked | 38.605377 | 0 | 0 |
32 | Locked | 38.983261 | 0 | 0 |
159 | 96 | 4K | 1840 | QAM4096 | 759 |
159 | Locked | 39 | -4.5 | 537990165 | 208 |
2 weeks ago
1 | 49600000 | 45.020599 | 5120 KSym/sec | 64QAM | 1 |
2 | 23600000 | 43.520599 | 5120 KSym/sec | 64QAM | 5 |
3 | 30100000 | 43.520599 | 5120 KSym/sec | 64QAM | 4 |
4 | 36600000 | 44.020599 | 5120 KSym/sec | 64QAM | 3 |
5 | 43100000 | 44.520599 | 5120 KSym/sec | 64QAM | 2 |
1 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
6 | 10.0 | 47.5 | 2K | QAM128 |
6 | OFDMA | 200 | 53.9 | 0 | 0 |
2 weeks ago
Fri Apr 19 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri Apr 19 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Apr 18 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Apr 18 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Apr 18 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Apr 18 | 6 | CMSTATUS:US_Diplexer_Mode_Change_Ignore: (TLV-9) , (5-85) ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Apr 18 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
2 weeks ago
It looks like your Hub had a factory reset on Thursday. The stats are all normal except for the 3.1 Upstream channel. That might explain the constant lost packets. I think you are going to need a technician visit, and probably a new Hub.
2 weeks ago
Correction to my last. Having checked again I don't think that upstream reading is causing your problem. But your live BQM is still having regular packet loss, which should not happen.
You really need a technician visit to sort this out. Perhaps a VM person can pick this up and help.
2 weeks ago
The BQM tells me that your locality is busy on the Internet when the upstream latency (blue) is densest. That said, we’ve seen much worse. But Jpeg1 has spotted the consistent low level packet loss across the 24 hours which is not significantly denser during the busy hours. This suggests noise and its is usually the upstream frequencies that are more prone to noise.
The Forum Team need to arrange a tech visit and need to take the BQM into account. It would help to post ta new BQM to show that this lost packets happen all the time.
If the problem was in the downstream, it would show as Post-TS errors.
2 weeks ago
Hi Sephiroth,
Please see below my BQM for today:https://www.thinkbroadband.com/broadband/monitoring/quality/share/81d2668b837c5d1c25f275155ddea6b646...
I'm talking in private messages with a VM person as we speak to arrange a technician visit however they've told me that if they find the issue is my equipment and not theirs they're going to charge me £25?? So for that reason I want to make sure I've done everything I can to try to fix this myself before concluded that it's a fix Virgin Media need to do. Any advice?
I also asked to switch my Hub4 for a Hub5 but they told me there would be another extra charge for this, despite me being told that there are faults with the Hub4 by multiple people online so it seems a bit unfair for them to charge me for me having issues with their service. It's just a bit of a nightmare really.
Any advice on stuff I can try before a technician visit? Thank you very much for the help btw.
2 weeks ago
The BQM still shows the small but persistent packet loss. I assume that you are in router mode so that there is no third party equipment involved; right?
One thing you could do, and it would be valuable, is to see what's happening with a neighbour. The techs won't find anything wrong with your circuit unless they put a noise meter on - but it helps to have a neighbour's BQM so that they can get the matter referred to Network Team.
