How to connect device to WiFi pods
Tp50
I have a WiFi pod and can stand next to it and it won’t connect? Can you force it to pick up device. WiFi drops out on device intermittently in this area because it’s still looking for hub
1 ACCEPTED SOLUTION
Accepted Solutions
You cannot force a pod to pickup a device. You should have the pod equal distance from the hub and the device. There is nothing magic about a pod, it just picks up a WiFi signal and retransmits it. So if you are next to the pod, your device will receive exactly the same strength signal from the hub as the pod. Contrary to what VM say there is no such thing as a WiFi ‘booster’, pods just extend the range of the WiFi signal, they cannot increase its strength.
3 REPLIES 3
Steven_L
Hey Tp50,
Welcome back to the community and thanks for taking the time to post. I’m sorry to hear of the issues that you’re having with your connection to your WiFi pod.
Is your pod definitely connected to your hub and working correctly? Are you able to connect to the pod via the Connect App?
Kind Regards,
Steven_L
It is now seems I had a connection issue for a short while, even with no lights flashing.
can see on the app it’s connecting to the pod.
