on 24-03-2024 14:28
Hi all need some help. I have aVM hub 5 set on modem mode and 3 deco X20 mesh set up. The problem is connecting Phillips Wizz lights. When the app checks the network “ broadcast (UDP) on local network “ fails. I did manage to connect one bulb but wouldn’t connect any more. Then when I disconnected it if wouldn’t reconnect. Any help would be appreciated so long as it’s not to complicated 🙂🙂
on 24-03-2024 14:38
Is the Deco system broadcasting a single SSID - or have you separated them into two - 2.4 & 5 GHz ?
If one try separating them and to force the lights to connect on the 2.4 only band.
on 25-03-2024 09:23
they are on the same but I went into the app and turned the 5 ghz off but it made no difference
25-03-2024 12:29 - edited 25-03-2024 12:31
Not a VM problem try
unless its a routing issue
