Landline fault after installation of hub 5
ladylyn
Since installing hub 5 i can ring out on my landline but can't ring in.Does my land line have to be connected to the hub as well.
Thank you
Lyn
1 ACCEPTED SOLUTION
Accepted Solutions
Matthew_ML
Hey ladylyn, thank you for reaching out and I am so sorry to hear this.
It does like your on a digital line so the cable would need to be plugged in the back of the router which sounds like it is or you wouldn't be able to ring out.
I am going to send you a PM to look into it. Cheers
Matt - Forum Team
New around here?
3 REPLIES 3
Matthew_ML
Matt - Forum Team
New around here?
Thank you matt much appreciated
No problem you should see a message from me in your inbox . Cheers
Matt - Forum Team
New around here?
