Are you in Router Mode or Modem Mode ?
In Modem Mode the power light should be magenta.
In Router Mode the power light should be white.
In either Mode the red power light is an indication of over heating and most not be ignored.
Ensure that the Hub is in a well ventilated area and nothing is blocking the vent holes on the sides of the Hub.
If the Hub is in a clear area and is cool to touch and the red power light remains on the Hub must be replaced.
If the Hub is in a clear area and is hot to touch and the red power light remains on the Hub must be replaced.
Do not be fobbed off with "if it is cool it will be OK" or "Just blow a fan over it", this is dangerous advice.
When you go out or retire for the night ensure that the Hub is unplugged from the mains.
The only fix is a replacement Hub.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 10 days average) until one of the VM Forum Staff comes along.
