MalandBren75's avatar
MalandBren75
Dialled in
Hub red light
My virgin hub is showing a red light. It is cool to touch and is well ventilated also everything is working as it should, this forum recommends a new hub is required is this correct and if so how do I get one as I can’t get through on 150
  • Finally managed to get through to 150 they ran tests to say all is ok and that the red light is normal, I find this strange as VM guidance says it is a problem and this has never been on in the past
  • Do you know what version of hub you have?  Are you operating the hub in router or modem mode?
      • Martin_N's avatar
        Martin_N
        Hi MalandBren75,
        Thank you for your post. We are more than happy to look into this for you.
        I will private message you now to confirm your details.
        ^Martin
    • An engineer came out and said red light means there is an issue and swapped it straight away and everything has been fine since
    • Matthew_ML's avatar
      Matthew_ML
      Glad to hear a tech has come and fixed this for you.
      If you need anything going forward you know where we are.
