4 weeks ago
Hi, I am experiencing intermittent packet loss which is causing connectivity issues and the audio on my Teams calls to drop. This is affecting my ability to work from home. This is happening on multiple devices and only on my Virgin Media connection.
Is there anything I can do or does this need to be resolved by Virgin Media?
I've tried the usual... reboot router, use wired connection, test using mobile phone connection (no issues)
BQM Graph:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/fcc67bab99a27431ac6c0b8208ba34b044...
3 weeks ago - last edited 3 weeks ago
BQM looks poor. What devices do you have connected to your Hub on ethernet cables ?
Can you do this....
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax and ethernet cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing. When its light, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables. Then switch the Hub back on and leave ~5 minutes
When all done, Post up your Hub/network connection details and someone will check to see if there is a problem there. In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
Hi John,
Thanks for your detailed response. I checked and re-seated all the connections and all look good. I'm still getting the issue and still seeing latency spikes and dropped packets on the BQM. I still have a Super Hub 2. I do have devices connected to the hub via ethernet cables (mesh wifi, tv, etc.)
Downstream DS-1 DS-2 DS-3 DS-4 DS-5 DS-6 DS-7 DS-8
Frequency (Hz) | 258750000 | 266750000 | 274750000 | 282750000 | 290750000 | 298750000 | 306750000 | 314750000 |
Lock Status(QAM Lock/FEC Sync/MPEG Lock) | Locked | Locked | Locked | Locked | Locked | Locked | Locked | Locked |
Channel ID | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 |
Modulation | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM | 256QAM |
Symbol Rate (Msym/sec) | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 | 6.952000 |
Interleave Depth | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 | I=12 J=17 |
Power Level (dBmV) | 2.50 | 3.84 | 4.21 | 4.08 | 4.05 | 4.18 | 4.38 | 4.68 |
RxMER (dB) | 34.63 | 35.42 | 35.42 | 34.35 | 34.08 | 35.42 | 35.60 | 35.78 |
Pre RS Errors | 5328081 | 375827 | 341182 | 5241796 | 4208046 | 4938736 | 2623963 | 988093 |
Post RS Errors | 99276 | 15229 | 17239 | 576147 | 182399 | 57698 | 58165 | 45088 |
3 weeks ago
Upstream US-1 US-2 US-3 US-4
Channel Type | 2.0 | 2.0 | 2.0 | 2.0 |
Channel ID | 4 | 2 | 1 | 9 |
Frequency (Hz) | 30100000 | 43100000 | 49600000 | 23600000 |
Ranging Status | Success | Success | Success | Success |
Modulation | 64QAM | 64QAM | 64QAM | 16QAM |
Symbol Rate (Sym/sec) | 5120000 | 5120000 | 5120000 | 5120000 |
Mini-Slot Size | 2 | 2 | 2 | 2 |
Power Level (dBmV) | 45.75 | 45.50 | 45.75 | 46.00 |
T1 Timeouts | 0 | 0 | 0 | 0 |
T2 Timeouts | 0 | 0 | 0 | 0 |
T3 Timeouts | 6 | 0 | 0 | 2 |
T4 Timeouts | 0 | 0 | 0 | 0 |
3 weeks ago
First Time | Last Time | Priority | Error Number | Description |
23/05/2024 09:26:17 GMT | 23/05/2024 09:26:17 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
23/05/2024 09:26:07 GMT | 23/05/2024 09:26:07 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
22/05/2024 18:40:16 GMT | 22/05/2024 18:40:16 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
22/05/2024 18:18:08 GMT | 22/05/2024 18:18:08 GMT | Warning (5) | 84020200 | Lost MDD Timeout |
22/05/2024 18:18:02 GMT | 22/05/2024 18:18:02 GMT | Warning (5) | 84020200 | Lost MDD Timeout |
22/05/2024 18:17:56 GMT | 22/05/2024 18:17:56 GMT | Warning (5) | 84020200 | Lost MDD Timeout |
22/05/2024 15:05:34 GMT | 22/05/2024 15:05:34 GMT | Error (4) | 68010300 | DHCP RENEW WARNING - Field invalid in response v4 option |
22/05/2024 07:10:24 GMT | 22/05/2024 07:10:24 GMT | Critical (3) | 84000500 | SYNC Timing Synchronization failure - Loss of Sync |
22/05/2024 04:17:24 GMT | 22/05/2024 04:17:24 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
22/05/2024 01:35:50 GMT | 22/05/2024 01:35:50 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
21/05/2024 15:06:42 GMT | 21/05/2024 15:06:42 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
21/05/2024 15:06:30 GMT | 21/05/2024 15:06:30 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
21/05/2024 15:06:20 GMT | 21/05/2024 15:06:20 GMT | Warning (5) | 66050300 | Auth Fail - Web login failed. |
21/05/2024 14:49:31 GMT | 21/05/2024 14:49:31 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
21/05/2024 14:49:21 GMT | 21/05/2024 14:49:21 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
21/05/2024 14:33:05 GMT | 21/05/2024 14:33:05 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
21/05/2024 14:32:55 GMT | 21/05/2024 14:32:55 GMT | Warning (5) | 66050300 | Auth Fail - Web login failed. |
21/05/2024 13:13:12 GMT | 21/05/2024 13:13:12 GMT | Critical (3) | 82000200 | No Ranging Response received - T3 time-out |
21/05/2024 11:00:37 GMT | 21/05/2024 11:00:37 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
21/05/2024 11:00:26 GMT | 21/05/2024 11:00:26 GMT | Warning (5) | 66050310 | Auth Success - Web login successful. |
The SH2 is really outdated in itself - I’m surprised you haven’t been contacted about this already.
I’m not familiar with the stats from the SH2 (they are a little different to the newer hubs)
However:
There’s a lot of PostRS errors (which support the fact that you are experiencing packet loss) - when was the router last restarted? If if’s been a while, might be worth restarting to confirm that they are still rising. Either way, repost in a few hours to confirm they are rising.
One of the other issues I’ve identified is that one of the upstream channels has a modulation of 16QAM (should be 64)
3 weeks ago
Thanks RT123
I restarted the Hub on the 21st:
They are still rising:
Post RS Errors | 102293 | 15655 | 17773 | 578402 | 183937 | 58433 | 58685 | 45837 |
3 weeks ago
Thanks for confirming that.
Given the PostRS errors are still rising, an engineer is needed - you can either wait for a few days (although I’ve seen some responses take longer) for the forum team to respond or contact the team over on Facebook or X (which in my experience is quicker)
X page: https://twitter.com/virginmedia
FB page: https://www.facebook.com/virginmedia/?locale=en_GB
3 weeks ago
Yes they shouldnt be that high even on an SH2. /I have asked VM to come here and look at your connection - but whilst waiting see this old post of mine - but might be worth exploring too
________________
There is another possibility, there have been several threads on here recently where similar BQM latency/packet loss problems were eventually pinned down to a dodgy piece of connected kit affecting the connection . Bad connectors on ethernet cables, NAS Drives and faulty network switches being high on the list of culprits.
What I advised was... if you run the BQM for 24h to get a picture of the issues (you have done this) - and then unplug all the ethernet cable connections from the Hub and just let it run - overnight is best - then in the morning look at the BQM and see if it has cleaned up. If it has - plug the devices back in one at a time for an hour or two until the problem reappears and that should indicate where to look for what is causing the issues - Start by changing to new good quality ethernet cables, minimum of Cat6a spec.
Examples.
See message 21 in the first thread, 13 in the second and 5 in the third and 5 in the 4th
https://community.virginmedia.com/t5/Networking-and-WiFi/Internet-connection-dropping/td-p/4781287/p...
https://community.virginmedia.com/t5/Networking-and-WiFi/Intermittent-Connection/td-p/5069984/page/2
https://community.virginmedia.com/t5/Speed/Issues-in-GU22-area/m-p/5400109#M307543
https://community.virginmedia.com/t5/Networking-and-WiFi/BB250-Connection-dropping-frequently/m-p/54...
3 weeks ago
Hi @faze82
Thanks for posting and welcome to the community. Sorry to hear of the issues with the broadband. You'll need an engineer visit so I'll send you a PM now to book this in.
Best wishes.
