on 13-02-2024 23:50
Hi, I'm on the M250 Broadband package, but my hub is a Hub 2. My broadband download speed is capped at 100Mbps. Please help arrange a replacement Hub. Thank you.
Answered! Go to Answer
on 25-02-2024 12:48
Thanks for speaking with us today @cp3t3r5
I'm glad we have been able to assist and arrange a delivery for the hub.
All information has been mentioned within our private chat.
Let us know if you need anything else and we'll assist.
Kind regards,
Ilyas.
14-02-2024 01:00 - edited 14-02-2024 01:02
Yes you could do with a new hub but likely your problem is something else are you testing be wire to the hub? does your device connection info show your link speed is 100Mb?
on 14-02-2024 01:22
on 14-02-2024 11:13
Thanks for your response. I'm doing a Speedtest from my phone, it never goes above 100Mbps, it used to go to 200+.
on 14-02-2024 11:15
Thanks for your response. Yes, I have a landline too. I could wait for VM to upgrade the hub in time, but the info on the M250 product says a Hub 3 or 4 is neccessary.
on 14-02-2024 11:22
That’s because the SH2 is no longer available. You should get at least a Hub 3. Nonetheless, the SH2 is still good for 250.
You need to use a wired test as VM only guarantee a WIFI speed of 30Mb.
As for the phone, sounds like it’s connecting on the 2.4Ghz band?
on 18-02-2024 12:41
Hi Cp3t3r5 👋
Welcome back to the community! Thanks for posting. Sorry to hear these concerns about the speeds reaching your hub and devices. If you require a hub upgrade as part of a package change in order to process the broadband speeds we usually arrange this when upgrading.
You can compare hub specifications here Virgin Media Hub 3, Hub 4 & Hub 5 | Hub Swaps & Upgrades . (Although sadly the hub 2 is no longer included.)
We will need to send you a PM to take a closer look at your speeds and offer support getting a replacement hub sent out if this is needed. I will do this for you now - you can find the PM in the top right corner of the page in your Inbox. 📩 We can then return to this public thread with another update when possible. Thank you for your patience in the meantime!
Wishing you all the best. 🌞
on 21-02-2024 13:42
Thanks for PMs and other helpful messages. My Hub 2 is old and I’m hopeful it can be replaced.
on 23-02-2024 17:11
Hi cp3t3r5,
Thanks for coming back to us on this one. With it being a Hub 2, we can certainly get a replacement sent out for you. I can see that you're in a private message with my colleague and they will come back to you as soon as they can.
Many thanks,
on 25-02-2024 12:48
Kind regards,
Ilyas.
