p3tzz's avatar
p3tzz
20 hours ago
Virgin Hub 5 Ethernet ports not working with CCTV
Hi I recently changed my hub 5 to another hub 5. Previously the Ethernet ports were perfectly fine and cameras cctv were working all good. Now all of a sudden the remote camera viewing has gone offline and Ethernet ports are not flashing behind the router. I have tried diff Ethernet cables and same issue. It’s a hub 5 and hik vision cameras. Please help. Thank you
    A new Hub has most likely a new WAN address.  For remote access you will need to reconfigure the cameras to suit .
  • jpeg1's avatar
    jpeg1
    How are the cameras getting power? The Hub 5 doesn't provide PoE.
  • Roger_Gooner's avatar
    Roger_Gooner
    Have you checked with a PC that all LAN ports are providing broadband?
