on 22-08-2023 22:37
The volume control doesnt work on my 360 remote
The tv box is plugged into an HDMI audio splitter that sends video to my projector and audio to my speakers
this setup works fine with my Chromecast but I cannot control volume when I use the virgin tv box
There dont seem to be any audio options that help me,
I dont want to pair the remote to a device, I want to change the volume that is outputted by the tv box
on 23-08-2023 08:54
The 360 remote only controls the TV or Soundbar volume when paired to these devices as it uses IR and needs line of sight to work, if you have both paired to the 360 you can then go to:
Settings, Audio & Video and use the Volume keys control to switch between the TV and amp.
